Interior lights
Discussion in '1st Gen - 1997 - 2002' started by wchnu, Jan 12, 2017.
  1. wchnu
    wchnu Member
    48
    Jan 12, 2017
    Baton Rouge
    Just got a 2001 Eddie B 5.4 when I unlock it or have the doors opwn all the intrerior lights and running board lights work. The problem is they will not come on when doors are closed and I press the buttons on them or when I turn the dimmer switch up. The dash lights do dim and get brighter though. Are there two different circuts here?
  2. Bedrck47
    Bedrck47 Full Access Members
    5,423
    536
    Jul 4, 2014
    Elizebethtown, PA
    Welcome to the Forum
  3. Bedrck47
    5,423
    536
    Jul 4, 2014
    Elizebethtown, PA
    Check fuses both under the dash and under the hood
  4. Bedrck47
    5,423
    536
    Jul 4, 2014
    Elizebethtown, PA
  5. wchnu
    wchnu Member
    48
    Jan 12, 2017
    Baton Rouge
    I should have said I did that all look ok. I can not figure out why they work with doors open or when I unlock with the clicker but will not work turning on dimmer switch or pressing the buttins
  6. Bedrck47
    5,423
    536
    Jul 4, 2014
    Elizebethtown, PA
    Very possible that the main light switch is not making contact when you move it to the on position
    Can you read and understand wiring diagrams
  7. stamp11127
    stamp11127 Super Moderator Staff Member
    60
    4,824
    585
    Mar 10, 2012
    Temple, Georgia
    Welcome to the forum.
    You're in the south so you should know the redneck method........ just open the door while in motion.
  8. wchnu
    wchnu Member
    48
    Jan 12, 2017
    Baton Rouge
    Yes I can
  9. wchnu
    wchnu Member
    48
    Jan 12, 2017
    Baton Rouge
    That is the easiest thing lol
  10. Bedrck47
    5,423
    536
    Jul 4, 2014
    Elizebethtown, PA
    Attached prints
    You will need to pull the main light switch to test it
Share This Page
