As my first post here,I want to thank you for taking the time to do this write up.
For roughly 3-4 months,I've been reading it over & over while I compile all the pieces to do the swap on my 04 Expedition. That time has come
This thread is going to be a great help. I do have afew questions,Im hoping you may be able to shed some light on.
- I've noticed that we have a 6 rib serpentine setup,while the F150's & Lightnings have 8 rib pulleys for their accessories...more than likely why we have that extra idler on the drivers side,just a guess.
From looking over my truck & the best photos I can find of lightning & F150 timing covers,im thinking I can remove that pulley where the bridge would mount,and simply run the proper length 6 rib belt,which would be alittle shorter. The span from the alternator to the power steering pump would be identical to the F150's,lengthwise...only difference being that I would be a 6rib vs their 8rib eight setup.
Is my thinking wrong on this? Im trying to prepare as much as possible for the least amount of down time. least amount of surprises.
I was also curious, if there were any belt alignment issue with mounting the blower pulley on the 6 rib dampner? Im assuming that bolted right up w/no alignment issues? And when you purchased your lightning alternator,did yours come with a 8 rib pulley & you swaped your 6rib on? are the threads counter clockwise on the alternators,if you happen to know?
Sorry for so many questions. Not many folks have tackled this job & documented online like this,so I knew where to ask when the time came
Mike
