Red92lx
Hey guys,
So over the last few weeks I've noticed a slight drop in my 2003 expeditions (eddie bauer) brake fluid. Truck currently has 141K and runs good, but has it's share of problems. I will list them below at the end of this post. So I climbed under the truck and found the brake lines are rusted pretty bad in the middle of the truck, where they turn under the fuel tank. One is definitely leaking (or seeping), the other is not far behind. After doing some online research, this isn't a cheap job to have repaired and I don't have any experience repairing brake lines, so everything would be new to me here. I've seen people talk about $1000-$1900 repair bills to replace all lines and I can't justify those costs with the current problems the truck has.
I am asking for your opinions and what you would do in this case, I like the truck and it runs and shifts well. It's a total bummer to have to junk a truck at 141K. The truck overall still looks pretty sharp, even for it's age.
List of things currently broken or not right on truck- (some are minor I realize, but trying to give you a comprehensive listing)
- Rad support is totally rusted and supported with wood and straps
- abs modules failed, so abs and advanced trac is disabled
- front diff is leaking at pinion bearing. currently just refill every 3-4 months
- rocker panels completely rusted out
- oil leaking from valve cover or head gasket. stop leak every oil change seems to stop the leak.
- rear wiper fuse pulled due to motor draining battery.
- rear heat/ac/ motor recently started clicking but still works.
- pass. window is non-operative.
- rear tailgate is faking paint (just using touch up paint to repair)
- driver seat wont remember memory for 2nd setting.
- pass seat seat heater/ac is not working
I know the list is long, but I still enjoy driving this truck and it pains me to junk it. If I could limb it along cheaply, I would, but I have two kids and it needs to be safe enough for them to ride it. Is there a safe, cheap way to keep this old girl going, or is she done?
