What do you guys think? I'm thinking I should jump on it for $5k. Wanted opinions from the experts! And this is the same one I've been toying around with for a week now on this forum in one other post about "rust". I've got detailed plusses and minuses below.
2001 XLT 4X4 with 110k (verified mileage)
Positives:
Negatives:
For what it's worth, I'm a total DIYer with no time due to kid sports. But I guarantee you I'll wire wheel all that surface rust off under the truck and reshoot it in the first month! Worth the money?
- 3 owners + originally a lease (autocheck/carfax verfied this) - last owner had since 2004
- Cloth interior (8 out of 10 condition) with a 6-disc changer)
- Exterior paint (8 out of 10) with glossy paint
- New tires Brigestone tires
- Nice book of receipts of all work done in past five years
- Runs and drives well. Good temp and oil pressure, braking and cornering. No suspension noise or bounciness. No warning lights, etc.
Positives:
- New plugs and all new coils at 100k
- No coolant leaks at 90 degree elbow (on #2 / #4)
- No engine/tranny leaks or leaks from the oil filter lines/hoses
- No engine ticking
- No tire squat (newer ball joints)
- Good sway bar bushings
- Cold a/c - recently serviced (replaced a leaking 2-piece hose)
- No apparent water leaks from the windshield
- No rust on the underside of the doors, radiator support, quarters, wheel wells, rocker panels, etc.
- No door ajar warning lights
- Has the "E" code transmission
- 4 wheel drive (high and low) engage like it should
- No torque converter whine
- New evaporator cannister under rear LH side of truck
- 5w 20 valvoline high mileage oil changed every 3k miles
- Differential, transmission and transfer case fluids changed as scheduled
- New throttle sensor
- All window regulators are good to go / windows all work
Negatives:
- Noticed an exhaust manifold stud broken off / surface rust in this area
- Original shocks
- Odometer is flickering off and on
- Yellowed headlamps
- Surface rust on the undercarriage sheet metal and frame (driveshaft, differential, axle, trailing arms, suspension, etc. from being in Colorado for the first year of it's life)
- K&N filter (negative?)
- Slight oxidation on the rims
