http://www.api.org/~/media/Files/Ce...ications/MOTOR_OIL_GUIDE_120116_FINAL_WEB.pdf
It appears I made a mistake. I confused the general gasoline engine spec with the new diesel spec. I apologize if it was misleading. The new Gasoline oil spec has been pushed off to be released in 2019, I had heard it was already released.
Draft copy of new Gas spec: https://passenger.lubrizoladditives...016/07/02-ILSAC_gf-6a_2-13-14_draft_rev_5.pdf
I just bought LEDs to replace the interior lights. I hope to be installing them tomorrow.
I changed all of them on Saturday including the two in each visor. The only problem that I had was I tried to change the ones in the license plate lights and the tab snapped off so I put it in as a warranty claim. I've only had it for a month so the tabs shouldn't be breaking off. What would it be like in 4 or 5 years...All you need is 5 minutes and a trim puller (vinyl prybar)
Just poke it in and pry off the button/lens thing
We all use diesel spec rotella... in anything from gasoline bimmers to motorbikes
And would DEFINITELY stay with diesel spec if a gas spec came out
Since...we use it BECAUSE it is diesel spec.
On the right side there is a plastic tab that you push with your screwdriver to release the license plate light fixture so you can change the bulbs.Tab what tab?
It says 912 in the owner's manual. It is just one one of those two pronged push in lamps. I'm going to use one of the same ones I used for the interior lamps.Andy whats the part number for the license plate bulbs? Did you change your puddle lights under the exterior mirrors to? If so what bulb is that?
I'm looking to swap the exterior for LEDS. Not really worried about the interior
