G
Guest
Hi Guys, I am new to this forum, just puchased a 2000 XLT. How do you reset the keypad code to unlock the door in the event you leave your key in the car?
if u know the code and just want to change it...there are steps for it...the code can be found in ur truck and youre good to go if you lost it
I assume that you know the original keypad code. If you don't, it's printed on a box located under the dash in the vicinity of the parking brake mechanism. You cannot erase the original code, but you can add ONE supplemental five-digit code to the system. How? Key in the original code. Then within three seconds press the 1|2 button, then key in your desired five-digit code. Done. Repeat this process (using the original code) anytime you wish to change the supplemental code.
