paul_smith_347
So I finally had some time today to check out the underside of the expy today and do some diagnosis. After pulling the shift motor off the T-case, I started the expy and moved my selector switch to 4HI. I wheeled under it again and saw that the motor had not moved a bit. The motor case is completely covered in deep rust, so I'm assuming the motor is siezed.... easy fix. Then I put everything back together and put the rear on jack stands to check the Torque on Demand system. With the rear on jack stands, I put the expy in 1st. The wheels spun around about 1 time or so and stopped. I figured the TOD had engaged. I eased on the gas and felt it get a load. Just and the truck started to go foward, there was a heavy "cluck" in the driveline and all load was gone off the motor. I repeated this two more times and the same thing each time. So then I put her back on the ground. I went to a gravel road and did a break torque to see if the sytem would engage...... Nothing with the rear wheels on the ground and spinning... No TOD engaging, no clunks, just spinning rear tires..... Anyone know whats going on with that? Possible the vaccum actuator not engauging the hubs all the way or what do I need to check next? I have a feeling a new shift motor and Brown wire mod are in my future...... Any help is greatly appreciated.. LOL if that wasn't enough trouble for one day, I noticed that my rear upper and lower trailing arms have several spots where they are rusted ALL the way through. I have a feeling a lift and tires are gunna have to wait untill all this stuff is repaired. Also, my factory tow package has 355's instead of 373... been a dissapointing afternoon.....
