Does anyone else hate Ford seatbelts?
Miekk
Madison Lake, MN
My chevy and dodge both have the belt buckle at about the left shoulder height where I can reach up with either my left or right hand and pull it easily down across to plug it in. Stupid expy and mustang buckles lay at the bottom so you can't get it with either hand without twisting and straining in the seat to get at it.
That isn't even the worst. The door arm rests come in contact with the side of the seat in both vehicles and the belt stays behind the seat so you have to pull the belt through the resistance and out from between. Then you have to find the bucke and slide it up so you can then finally pull it down across like chevy and dodge does so easily! :banghead:
\rant.
sgtowing
Supporting Members
Valrico, Fl
I shouldn't say this but I wouldn't know. I don't wear mine.
Sent from my DROID BIONIC using Tapatalk 2
VexedEX
I honestly hate seat belts but they are there for good reason. Sometimes I take a turn and they lock~~~~ I have to move to see were I'm going!!!!...... Good idea but bad idea. Good for us in long run soooo I wear them!
Miekk
Miekk
Madison Lake, MN
It's wearing the finish off the side of the seat where it gets pulled through every time.
jdan
CT
Never had an issue with mine yet.
Nice part is if I don't feel like putting it on it stops reminding me after 30 seconds.
panda24619
San Diego
no problems. even in the back and 3rd row. i ALWAYS wear mine. only time i dont is moving my truck from one end of the driveway to the other. but if im going down the street i put it on. ALWAYS. saved my parents, sister and aunt and uncle numerous times.
toms89
technical advisor
MD
If you think their bad when they lock up you should try 5 point racing harness after its snugged up.
Miekk
Miekk
Madison Lake, MN
You guys with no issues obviously don't know any better. I'm not so Blue blooded to admit the other manufacturers have Ford beat in this area.
Newport News, VA
this is the only ford i've ever owned...not our fault you got "that one" with the seat belts
toms89
technical advisor
MD
:shrug: Get in my expy reach over my left shoulder with my right hand...pull seat belt over and plug in. One hand...smooth motion..no issue?! Sorry??
panda24619
San Diego
i use two hands.
VexedEX
I will have to check if mine has.... I put seat covers over it first couple days I had it. I would do that to keep it from getting even more worn out. That is if you don't mind seat covers... My Husband hates them....lol
Stoned06
Milwaukee
Never a problem with mine. The buckle stays near the top of the strap when not buckled.
I was lucky enough to be wearing mine when I had a wreck when I was 16. Weird thing is, I wasn't wearing it for nearly the whole ride home (30 minutes), but i put it on backing out of a friends driveway after dropping him off. A minute later, I slammed into the back of a car sitting in the middle of the road. Since then, I always wear it. Without the seatbelt, I doubt I would be typing this.
