Correct PCV elbow?
DR3W
L.A. - IE/SoCal
Hello everyone, a PCV elbow on my truck turned to crap so i built my own temporary one. But now its time for the right one. I want to make sure i order the correct part.. Thanks guys!
Heres the pics:
:Rock on:
FordandPolaris
Saint Cloud, MN
Honestly I would just go to Ford and get the entire assembly. The valve itself that plugs into the valve cover is pretty cheap, so it would not hurt to replace. It cost me about $40 at the stealership.
My elbow was more 90 degree shaped, but that means nothing as you have a totally different engine from a different era in the expy motor and they most likely changed small things like that.
DR3W
DR3W
L.A. - IE/SoCal
The dealership sells a complete pcv kit? With all the little things?
Because the one elbow shown is the only part thats bad.
Thanks, btw
Lightnig
Behind you
Indeed they do
This is one I picked up for my 97 5.4.
I suspect the one to fit your truck will be slightly different, but the exact same idea...
DR3W
DR3W
L.A. - IE/SoCal
Oh yeah duh, sorry i wasnt thinking clearly.. haha Thank you guys, ill get one this weekend!
I should prolly get a new valve soon too.......
FordandPolaris
Saint Cloud, MN
The valve will come as a part of that assembly pictured above. Its literally just a piece of plastic that sits over that hole visible in the pic until the positive pressure in the crank case forces it to float up and open.
DR3W
DR3W
L.A. - IE/SoCal
Thanks alot man!
