VIN decoding & options/packages
RI-Matt
Rhode Island
just curious.. bought used a couple months ago and it came with a trailer brake on it.. thank you
1fmpu16566la46916
Yup came with HD tow.
Build Date: 12.12.2005
Vehicle Line: Expedition (2003-)
Body Style: 4 Door Wagon
Version: Ford Series
Engine: 5.4L 3V V8
Transmission: 4 Speed Automatic 4R75E Livonia
Drive: 4WD
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning: HD Manual Air Conditioning
Paint: Silver Birch Metallic
Medium Flint Interior
Less Underbody Protection
With Manual Liftgate
119"/3023MM Wheelbase
XLT
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Michigan Plant Built
U.S. Sales
Less Convenience Group
Less Exterior Dress Up Package
Less Sales Badge
Less Military Vehicles
XLT Sport
Less Exterior Appearance Pack
Less Functional Upgrade Pack
Less Memory Package
Feature Content Group 1
2006 JOB #1 Program Control
Less Electronic Stability Control
Less Special Language Label
Owner Hand Book Pack
With Fixed Rear Vent Quarter Window
With Privacy Glass
Standard Ovrhed Console & With Rail
With Full Floor Console
Adjustable Accl/Brake Foot Pedals
With Carpet Floor Covering Level 1
Front Floor Carpet Mats
Rear Floor Carpet Mats
Sunvsr-Dual/Light/Illum/Mirr-Driver
Pass Sunvisor-Dual/Lt/Illum/Mirror
Less Running Boards
With Integrated Roof Rack
With Accent Wheel Lip Moulding
With Step Bar
With Dipping Rear View Mirror
With Drivers Power Mirror
With Power Passenger Mirror
With Black Exterior Mirror
Less Signal Mirror System
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Cloth 2nd Row Seat Material
Second Row 40-20-40 Seats
With Third Row Power Folding Seat
With Driver 6 Way Pwr.Seat Adjuster
Less Adjustable Passenger Seat
Less Programmable Driver Seat
With 3rd Row Cloth Seat Material
With Heavy Duty Trailer Towing
With Front Towing Hook
Less Engine Oil Cooler
Body Coloured Exterior Door Handle
With Door Entry Remote Control Unit
Less Keyless Entry System
Less Sun Roof
Fr Bumper - Body Colour Lwr Accent
Rear Bumper-Body Colour/Lwr Accent
With Front Licence Plate Bracket
Less Air Curtain Restraint
With Driver Air Bag
With Passenger Air Bag
With E-Coated Steel Spare Wheel
With 4 Wheel Tyre Pressure Sensors
Less Rear Shock Absorbers
7.5 X 17" Cast Alloy Wheel
P265/70R 17 A/T OWL
With Super Engine Cooling System
Less Immersion Heater
With 49 State/Non Green State Req
With Standard Suspension
3.73
Rear Axle Limited Slip Differential
Less Exhaust Pipe Extension
With 4 Wheel Disc-Brake
Normal Fuel Fill
Heavy Duty Aux Trans Oil Cooler
4X4 2 Speed Transfer Case With Tod
Non Locking Fuel Cap With BP Label
For Unleaded Fuel
Colour Keyed Steering Wheel
Less Steering Wheel Audio Controls
With MPH/KMH Speedometer
With Message Centre
With Reverse Proximity Sensor
Standard Duty Battery
Standard Duty Alternator
AM/FM CD Changer/Clock
With NAAO Radio Frequency
Less Headphones/Sockets - Rear
With Premium Sound System
Less Television Package
Less 4X4 Version Pack
Less Homelink
With Complx Refect Headlamp Design
Less Daytime Running Lamps
With Front Fog Lamps
With Interior Courtesy Lamp
With Automatic Headlamp On/Off
Generic Country Group 1
Less B&A Control Codes Issue 030388
Less B & A Control Codes (9270)
With Overspeed Warning Disabled
(+)"USA"
(-)"N"
(-) GVMT Service Administration
(-)"CDN"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"CHN"
(-)"CHL"
Less Fleet
Matt
kythri
Lebanon, OR
VIN Decoder | fleet.ford.com
Never gave it a shot myself, but I bet that would work. Yay google.
EDIT: Figured I would try it out with yours haha. You have an 06 Limited Expedition, but unfortunately it looks as though you can't tell the HD tow pkg from the VIN. Bummer because I always thought you could. On the old trucks (1st gens) if you had the transmission cooler behind the front bumper and a 3.73 rear axle, you had the HD towing pkg. No idea if that holds true with the newer models though.
It seems this isn't required, however.
Matt ran my VIN (Thank you!!!) and the 2000 I just bought does not seem to have any special transmission cooler (or it's not called out as such), and it has 3.55's (confirmed by door tag and the data Matt provided), but it does have the HD tow package, per Matt's info.
It's got a trailer brake installed, which I had figured was aftermarket, but some info in this thread suggests that it is a element of that package.
RI-Matt
Rhode Island
1fmfu16l44lb71422
thanks!!
Ooops almost forgot.
Build Date: 03.06.2004
Engine: 5.4L Modular SOHC V8
Transmission: 4R75W 4 Spd Automatic Transmission
Drive: 4WD
Axle Ratio: 3.73
Emission: California Emission Requirements
Paint: Ebony (Solid C/C)
Medium Parchment
XLT
U.S. Sales
Less Sales Badge
XLT Sport
Less Memory Package
Mid Year Change Program Control
Less Canadian Provinces/Territories
With Privacy Glass
With Mini Overhead Console
With Platinum Running Boards
Less Side Auxiliary Step
With Electrochromic R/View Mirror
With Driver Electric/Heated Mirror
With Pass Convex Elec/Heated Mirror
With Remote Keyless Entry
Power Tilt/Slide Sun Roof
Air Curtain Restrnt LH
Air Curtain Restrnt RH
P265/70R 17 A/T OWL
With California/Green State Req
3.73
With 9.75" Axle
With Non Locking Fuel Cap
For Unleaded Fuel
Basic Type Steering Wheel
With Speed Control
With Message Centre
Elect Prem Stro/Cass/Disc/Clock
Less Homelink
Ebony (Solid C/C)
(+)"USA"
(-)"N"
(-)"CDN"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"RU"
(-)"CHL"
Matt
RI-Matt
Rhode Island
The HD tow pkg usually comes with the special trans cooler, HD radiator, Class IV hitch with 4 and 7 pin connectors, and wiring harness for brake controller, so if you have the package you have these items.
If yours has a trailer brake unit installed ( usually mounted to the knee bolster) its aftermarket as Ford never made a factory installed one for the Expeditions until 2012.
Also, 3:73's were not part of the HD tow package.
Matt
Spooky
Thanks Matt, you rock!!
Ok, so I have the tow package.....but I have California emissions?!? CRAP! How do I get rid of that??
the_smiths_30
Pennsylvania
Trying to find out Standard vs Premium Towing Package
Hi Matt,
First I would like to say Thank You. I think it's awesome that you take the time to do this for people. We are looking at Expeditions to purchase. IT is critical that it has the Premium (HD) Towing package. We are looking at one that we like, and the sales person said it was standard. I'm confused, as it has the 5-V (Class 4 hitch), but the 4 prong plug. Could you possibly run this VIN, please ? Also, can you provide where you are getting this info, just in case this only has standard package, the search will continue. We need to be able to tow 7700 lbs and hopefully just install the Electic Trailer brakes, by mounting and buying the plug in jumper.
1FMPU165X6LA06564
sharprd65
