bricekin
Sounds good. My buddy knows quite a bit about cars, but he is speaking from his exp from 10 years ago. I wonder what has changed in 10 years. I look forward to your reply on this.
So many things have changed over the last 10 years in vehicles, let alone the products that interface with them. For example - Many newer Chryslers and GMs don't even need a remote start module in order to add a remote start. Through the use of databus (CAN or MOST) interfaces, many of the features that are offered by the manufacturers are now utilized directly through the data interface instead of chasing wiring all around the vehicle. Using one of these modules with the appropriate firmware, one can use a button sequence on a factory keyfob to start their vehicle.
Many Fords, including our beloved Expeditions, don't have the complex data networks needed to have this as an option. However, using a transponder bypass in the Fords, leaves the transponder interface completely untouched until remote start, when it sends a signal to the module to tell the vehicle that a valid key has been inserted and can begin the start sequence.
The fear of interfacing with a factory security system is a thing of the past. Whether through the data network (newer vehicles), or hardwired (many Fords or older vehicles), the remote start units have a factory arm/disarm trigger to keep as many things working the way they should. The capability of most reputable brand remote starts and alarms are only limited by the people installing them.
It was absolutely beautiful and I almost cried out in joy. But I decided to postpone my celebration till I got to the 20ish mile marker. Then it happened... "DING" "Tire Pressure System Fault".
