Interesting... mystery smoke from tailpipe
Kermit
NwPa
Hey gang... Here's an interesting one... 99 expy, 180k-ish miles, 100k tune up done by previous owners , 4.6 motor, runs strong and smooth but with a little vibration at startup idle. Most of my trips are shorter jaunts, 20-ish miles at 45-55 mph on rural routes but occasional highway jaunts, same distance obviously higher mph, 65-75 mph... This is where my issue comes in is highway driving.
So this problem is intermittent, doesn't happen every time I drive the highway and has never happened at the lower speed trips on the route drives. What happens is after I accelerate to get on the highway, get to cruising speed and set the cruise I get intermittent white puffs of smoke from my tailpipe. Some bigger, some barely noticeable which is why it has taken me this long to figure out it was actually me and not small fog banks... Its happened about 5 times over ten last 3 months so its not even happening evrytime im on the highway.
Scenario... Last trip to tractor supply , get on the highway, set the cruise at 75, go about 5 miles, notice the first puff of smoke... Engine running smooth, no smell of burning oil, no smell of the exhauast being too rich or lean... Go another mile or 2, another puff of smoke... And so on... Drop my speed down to 70, no difference... Drop my speed to 65, no difference... Drop to 60... No difference... Get to my exit and get off t go to tsc and see no more smoke below 50 mph. Get to tsc leave the truck running, gun it a few times, no smoke, smooth idle... Get out check the pipe... Good air flow and clear, no bad smells...no smoke, no dripping, nothing that would lead you to believe there is a problem.
So turn the truck off, do my shopping, maybe a half hour and leave. Get back on the highway, set cruise at 65, no smoke. Go almost all the way home, set cruise at 70, no smoke... Go a couple miles bump it up to 75, and get my first puff of smoke... Get off my exit... Have about 5 miles of route driving at 60 with cruise on, no smoke at all the rest of my trip home.
This has happened With cruise off and on, recently replaced the clock spring but it had done it once or twice before it was replaced as well. My check engine light is currently on, my guess is O2 sensor but have to get the code cecked, Again, doesnt do the smoking every highway trip, just occasionally. My lovely lil gremlin...
Sooo thoughts?
FordandPolaris
Saint Cloud, MN
Sounds like you are leaking coolant into the cylinders. Probably bad head gasket. Check your coolant tank and see if the coolant is low, make sure the truck is cold when you do it though.
Kermit
Kermit
NwPa
If it was a coolant leak wouldn't that be constant/consistent every time it was driven at those speeds?
FordandPolaris
Saint Cloud, MN
Kind of depends on the size of the coolant leak. There might not be a lot missing or leaking . Draw a line with a marker where the coolant is and watch it over a week's time and see if it changes.
You didn't sea foam the intake lately did you? Coolant and sea foam are the only two things I know of that cause white puffy smoke.
Sent from the Pocket Computer
Kermit
Kermit
NwPa
No seafoam but there was Marvel's mystery oil in the gas for that tank of gas.
FordandPolaris
Saint Cloud, MN
No idea what that is but it could be a possibility if that is some kind of fuel stabilizer you chose to add.
Yudaman
Southern Oregon
Beins it is a '99 with a 4.6, I would lay money that you have a head gasket problem.
My last '99 blew the head gasket at about 120k. That era of engines had a major head gasket problems.
Kermit
Kermit
NwPa
Again tho wouldn't it be consistent/constant if it were a head gasket issue, and wouldn't there be other indicators like loss of power, rough running, etc? Cat that had the truck before me who practically rebuilt the motor said all new gaskets, all new seals, there's no indicator of leaks when looking at the motor.
One other maintenance thing we recently did, changed air filter from the beat to death p.o.s one that was in there to a new Fram filter. That was done a couple weeks before this last incident.
Yudaman
Southern Oregon
White smoke would indicate water. The only way for water to enter the exhaust system is by it entering the combustion chamber,
As for all the time, not necessarily. It could be that the head gasket is sealing good enough during low RPM's/speeds. Once you start pushing the engine a little harder, by accelerating to highway speeds, you could be putting enough force on the gaskets for them to start leaking.
Toss a heavy trailer on the back and make it work a little. I would bet that you get quite a bit of smoke out of it.
For your sake, I sure hope that it isn't a head gasket. But with my experience with a '99 that had a 4.6 I doubt that I am wrong. :(
stamp11127
Temple, Georgia
Check the pcv valve and for oil leaks from the valve covers.
If the leak is "bad" enough it may show on a spark plug as being cleaner compared to the others - (steam cleaned).
Should the head gasket leak coolant into the crankcase don't run the engine. The oil will lose the lubrication properties and you will trash every bearing in the engine.
IMINYOURCHAIR
Altoona Alabama
there is also the possibility of coolant ingestion through the number one or five intake gasket, there is a coolant passage that is part of the intake assembly. my expedition had a failure on the number one side gasket resulting on an external leak but other factors kept the system pressure low enough that it couldn't get through the still weak seal. Here is the album for that repair.
This picture shows where the gasket was weak around the number one port. had it not failed on the inboard part and also had a major leak in the coolant pipe it would have started eating coolant. mimicking the symptoms OP has.
Kermit
Kermit
NwPa
OK... Did an oil change yesterday and there was no evidence of milkiness in the oil or white crust/crud around the filter threads/head, and my coolant level wasn't low...added barely a half cup of fluid, and level hasn't moved since, However one of my oxygen sensors (by the catalytic converter) was almost all the way out of place (was barely holding on by a thread or 2) and there was a small drip (not enough to leave a puddle) coming from the drain plug which I can't explain cause it was tight. Haven't had the truck on the highway since the oil change so I don't know if the intermittent smoke is still there as previously described.,
Bedrck47
Elizebethtown, PA
kindly update your signature line with year model and engine information. This can be done in the USER CP section as this information helps others give you replies specific to your expy
FordandPolaris
Saint Cloud, MN
There is a small o-ring that should be on the drain plug, if that is missing, it might drip slowly. Still keep an eye on the coolant, if you haven't seen white smoke since you added the water either then it hasn't had a chance to burn any off.
98EXPnSRQ
Sarasota, FL
My brother has a 98 SuperCrew with the 4.6L. He had the intake manifold coolant leak. When the engine cooled down, coolant would enter a cylinder and he would get a puff of white smoke when starting up. He didn't do anything about it. Enough coolant leaked into the cylinder that when he cranked it one morning the rod broke and the engine block cracked. When you start it cold, watch your exhaust immediately after startup. If you have white smoke, you have an internal coolant leak.
Kermit
Kermit
NwPa
I did state this in my opening statement. Is it also needed in the signature?
Kermit
Kermit
NwPa
There is no puff of smoke when starting the truck, ever. Is only happened a handful of times going over 65 mph. Thanks for the reply.
Kermit
Kermit
NwPa
OK ya lost me a little at the end there. The "either then" part is confusing, is there more?
Bedrck47
Elizebethtown, PA
by using the signature line your information will appear in your every post thus saving you the time to do it on the first page of a thread.
Where on the 2nd page does it show your information?
We are now on the second page and I will ask you to answer your own reply.
