2FordsChris
I have browsed about 10 of these same discussions, unfortunately most of them don't post the solution. I found 2 that were a missed connection. I have been back through it again and can't find any missing connections. Engine cranks and everything works other than no fuel pump and no dash warning lights. Brights indicator will illuminate, otherwise nothing when first turn on the key.
I did unhook almost everything as I took apart the entire colored dash trim and undid the black ducting component from the wiring harness. Tried to follow the manual, have seen you tube videos now where I could have made it much easier for myself.
I have reset the inertia shutoff switch, confirmed power to the shut off switch, bypassed shut off switch, checked all fuses, confirmed power to relay in the power distribution box, ohms tested relay and switched out the horn relay for the fuel pump relay.
I just checked for power at the fuel pump and appears to not have power. I disconnected the wire connection on the side of the fuel tank and tested with volt meter at the black and the black orange wire and the yellow/white and pink/black with key on and no voltage.
I have not checked for spark or checked fuel pressure as I do not have a gauge, but will get one if needed. I think I first need to figure out why no power to the fuel pump.
As far as I can tell, I do not have an anti-theft RAP module, but have done the reset things in the course of all of this and tried a different key.
Any other ideas out there? PCM? I am about to go check this now, but wanted to know if any one else out there had the answer on this one. Thanks ahead of time for your input.
