2018 ford expy
dlcorbett
Air Force
tx
What are some things features additions or changes youd like to see for the new expy?
1. Better packaged interior with better materials.
2. Better structure
3. More family oriented features...like how the 03 expy pioneered
Thats all for now, what are ur thoughts?
Otters07
South Carolina
More trim options...something like the 2015 f150 would be great. Can pick any package (platinum, King Ranch, Lariat - or EB) and add an FX4 upgrade. Skid plates, e-locker, upgraded shocks. Hell even just an FX4 Expedition option would be a nice addition to the "fleet".
Gruz7
North Smithfield, RI
gosh - an option for towing mirrors, please.
If you find the right thread in here someone found tow mirrors on 1aauto for like $225 and they are an easy install to 03+ expeditions!
But I would love to see the FX4 edition come back as well, preferably redone so you actually get something out of having the FX4. Also maybe a concept redesign sort of like a bigger version of the newer explorers because I feel that the expedition has remained "relatively" the same visually for the past decade.
WillieFlo
1. LED's inside and out with extra mirror side task lighting like on the new F-150's
2. More side bolstering of the bucket seats for lateral support.
3. Less freaking plastic inside and out
4. FX4 Package at the least!!!! RAPTOR type model?!?!? In my dreams!!!
5. No-touch liftgate
6. Allow center stack lighting colors to be changed like the rest of the interior "mood" lighting on/under dash, and in cup holders to match.
montecarlo31
get rid of that turd of an ecoboost for those of us who live in the south. They suck when the temps hit the mid 90s and only get worse into the high 90s and 100s.
LocDoc
Anywhere
A three-quarter ton Expedition is not on the books. It should also be noted that GM's Chevrolet/GMC brands have opted to "discontinue sale" on their Suburban 2500 and Yukon XL 2500 to consumers, for the foreseeable future.
They have been limited to fleet and government sales only. To buy them, they must be ordered by fleet companies or government agencies. The average consumer will not be able to buy a 2500 unit new anymore.
Half-ton construction and technology has progressed to where current half-tons tow and haul what older three-quarter tons could 10 years ago, and one-tons could 20 years ago.
The current Expedition (U324) tows up to 9,200 lbs (4.6 tons) of braked trailer. The Excursion (UW137) when first introduced in 2000 was rated for only 10,000 lbs of braked trailer in its best configuration. So the current Expedition is knocking on the Excursion’s door.
The Expedition already has larger heavier-duty disc brakes than the Excursion had, with larger swept area and larger disc diameter.
The next Expedition is expected to push beyond 9,200 lbs and into 10,000 lb braked trailer territory.
andrew_s
South of the Mason Dixon
I know, but still being able to get a 3/4 ton expedition would be nice! Eitherway the true limitation to the "wagon body" trucks is the lack of a 5th wheel or goose neck ability and such really cant go too high with hitch towing.
Eitherway a more powerful stout expedition would be awesome, although Im more then happy with my 1/2 ton and its 9200 towing capacity....
LocDoc
Anywhere
I think its tasked for 2017...I could be wrong
That's correct, however the model year is subject to change. It depends on the release date (beginning or end of year) and if Ford decides to market the Uxxx as a "early" 2018 model.
Expect it to bow as either a 2017 (if released late 2016) or 2018 (if released early 2017) model.
dlcorbett
dlcorbett
Air Force
tx
Will the styling favor more the new f150 or the explorer? I would prefer a more civilized f150 exterior with edge interior styling with flex interior packaging.
Gruz7
Hopefully the explorer cuz that f150 is damn hard to look at
Otters07
South Carolina
I like the new F150s...however it has to be the higher end models without all the chrome. Saw a few 2015 XLTs the other day... :puke:
montecarlo31
There are a couple of issues with this post. First is the GMT800 3/4 Ton or CK20906 has been dead since the changeover to the NNBS, no fleets can order the 3/4 ton regardless of quantity requested. The factory that built the 2500s had been retooled and they no long support that chassis. There are a few test mules running around with 3/4 ton running gear on the NNBS trucks but GM has not confirmed any of this.
Another issue is that neither the Excursion or current Expedition conform to the SAE tow rating standard so to say they tow X,*** lbs is just a claim with nothing to back it up. Ford has been trying to buck the tow ratings for years as they realize their trucks are over rated and most likely will not pass the J2807 tow rating requirements. Only the F-150 tow ratings have met the J2807 criteria while GM and Toyota have been using it for a couple of years now.
Why do you "need" a 5th wheel or gooseneck to pull significant weight? I have customers who safely and legally pull 40K lbs plus on tag trailers. Trailer towing ability, bumper pull or 5th wheel / gooseneck regardless of weight is simply how well the vehicle was engineered.
I've seen Land Rover LR4s and Discovery SUVs towing 7,500 lbs as well as 2nd generation expeditions. It's all in engineering, if you look ford bumped the tow ratings for the 2015 Expedition with no changes to the brakes, hitch or suspension. Do you think the Expedition is J2807 compliant? I am would make a well educated guess to say in it's current configuration it is not.
LocDoc
Anywhere
I was referring to the upcoming model. Only 1500s are available at the moment. The Suburban 2500 is returning for 2016 (model year) for fleet only: See link
2016 Chevrolet Suburban HD will be 3/4 Ton; Fleet Only
Another issue is that neither the Excursion or current Expedition conform to the SAE tow rating standard so to say they tow X,*** lbs is just a claim with nothing to back it up. Ford has been trying to buck the tow ratings for years as they realize their trucks are over rated and most likely will not pass the J2807 tow rating requirements. Only the F-150 tow ratings have met the J2807 criteria...
The next Expedition will adopt the new towing standards set forth by the SAE. Either way, Ford does test and evaluate the towing performance of its trucks and SUVs. They are not arbitrarily assigned tow ratings.
Toyota adopted SAE J2807 around 2013. GM only started using SAE J2807 for its 2015 models. So GM has not been using it for a couple of years as you stated. Ford also adopted SAE J2807 for the 2015 model year.
Actually, the "bump" in towing capacity was small and not praiseworthy. Therefore Ford did not push to advertise the change.
Expedition EL 4x4 saw a minor increase by 400 lbs; Expedition EL 4x2 saw a 300 lb increase; Expedition 4x4 saw a 200 lb increase; Expedition 4x2 saw no change. Nothing to write home about.
The rating change stems from the extra 55 lb-ft of torque the EcoBoost added (and at lower RPMs, then the 5.4 Triton was capable of), remapped electronic throttle management, and design changes to the Expedition's T1 frame (T1 platform), which can be seen by a trained eye, such as a additional structural cross-member.
These enhancements help the heavier models move more weight faster (thus offsetting their weight penalty) and translate to the slight "bump" in ratings. The disc brakes have always been rated for GCVW over 15,000 lbs.
k9education
I'd like to see paint that actually stays on the vehicle. I'm picky like that.
montecarlo31
...let's clear this up. The 3/4 suburban is NOT currently available nor have they released a date yet for the next ones. I have a 2016 FLEET order guide sitting on my computer at work and there is no 3/4 slated only 1/2 tons. If the Suburban 3/4 is released to fleet and is offered in anything other than fleet trim I will be ordering one. Once again NO FLEETS CAN CURRENTLY OR IN THE NEAR FUTURE ORDER 3/4 TON SUBURBANS.
Next, I am well aware of Ford's "testing" for their tow ratings and they are somewhat arbitrary, there is no internal standard for their ratings just what engineers feel "comfortable" with. We frequently get to test field follow products for ford, including the 6.4 and 6.7 diesel super duties as well as the 2015 F-150 so I probably have just a wee bit more inside knowledge than most on this subject. Bottom line is ford has not adopted this across the line as you IMPLY. ONLY READ ONLY the F-150 currently meets the standard. How many ford engineers have flown to your jobsites to see their trucks in action and test them? How many trucks has ford sent you to test and report back on?
Third, J2807 ratings, sorry GM is less than a month away from being a couple years on the J2807. Much longer than any ford product. Toyota has been since 2013, that is a couple of years, two = couple.
Frame change huh? Not quite. It has to do with consumers questioning why the SWB model can out tow the LWB model.
2013:
Model EXPEDITION AND EXPEDITION EL
FRAME: — Type Boxed, Front to Rear Axle — 6 Crossmembers (3 Boxed), 36,000 psi
— Section Modulus 24.7 cu. in.
2015:
hendricksen11
Wallops Island, VA
This is getting good.. and more model information than typically seen in most posts.. so I'll be following this post even with no intention (funds) to ever get a new expedition..
dlcorbett
dlcorbett
Air Force
tx
Hey locdoc, is there still gonna be a el version for the redesign? Ford should add a sliding second row seat for all seat segments.
