30" Light Bar
Chris_H
WI
Would you mind sharing some pictures of how you mounted? That's exactly where I want to hide this one.
Mine is a soye 240W bar that I believe is about 26" wide overall, and the mounting tabs fit onto the rails and I bolted in place. I'll try to get a photo.
Otters07
Otters07
South Carolina
My Rigid Industries on the F150 has side mounting tabs but this one has adjustable mounts across the bottom. Thinking of running a plate or strut across the frame and just attaching to that.
RedExpy
Kansas
Chris, were you able to get a pic of the mount? i want to do one for mine but have been perplexed on how to mount it.. looks great!!!
Chris_H
WI
I just went out to the garage and took a few photos. The first is looking down at the top of the bar, taken through a grill slot. Second is a close up of the end of the light bar, and the third is from under the Expy looking up at where the bar is mounted.
I would have preferred to go higher, but it is really quite effective where it is.
The photos didn't import with correct orientation. You may need to use your imagination. On a fairly old Macbook, if I select open attachment in new tab, the images show correctly. YMMV
1111ExpyEL1111
NW Wisc.
Chris,
Where did you buy this from? Can't find any sources via Google but I'm probably just not doing it right.
1111
Chris_H
WI
I bought it directly from the manufacturer.
http://www.gzsoye.com
Chris_H
WI
I sold the Expedition and bought a more appropriate tow vehicle. If anyone is interested in the light bar I used on the Expy, I'd probably sell it. I'm not sure I can mount it on the new truck.
toadeyes
I'm about to buy a 30 inch curved LED light bar any idea if it would be more easier to install the thing compared with the traditional straight bar?
Otters07
Otters07
South Carolina
What kind of truck did you get?
Otters07
Otters07
South Carolina
Wish I could answer that but I have still yet to find the time to install mine. Looks like I will try and remove the grill to apply a vinyl wrap here soon and will stick it back there while I have that off.
sharprd65
