3rd gen Anzo headlight review
JimmyM
Boston, MA
This a partial review. I'll explain later.
I purchased a set of Anzo 111114 (Chrome) off eBay at a discount due to malfunctioning LEDs (the small rows of 5 LEDs on each light).
They were installed as is with stock bulbs (included)
Pros:
1. Big improvement over stock lighting. Low beams have a sharp cutoff with the "step" for left-hand-drive. The high beams have good throw and are more focused than stock. Stock Highs would light only 2 phone-poles ahead, the Anzos light 4 or 5 poles ahead.
2. This is more subjective, but they look good.
3. Easy install and aiming
Cons:
1. It was really cold out when I did the swap. About 18F. Removing the stock lights was not a big deal, nor was the install. But I had to remove the light afterward and one of the spring clips snapped off the plastic "knob" it was attached to. I can fix it easily, but a note not to be too adventurous when it's very cold.
2. The left low beam needs to rotated a TINY bit counter-clockwise to level the beam. It's really noticeable only when the lights are pointing at a wall.
3. The high beams need a little tweaking with the aim. The beam hot spots point a little to the left. On a long straight, I can see that the trees on the left are lit better then the ones on the right.
4. The output, while well contained, is probably not a match for real HID projectors.
I have not wired the CCFL DRL lights yet. So I can't report on that. I'm waiting for warmer weather.
I thought that I might swap the bad LEDs for a series of 1/2 - 1W Amber LEDs and connect them to the signals. However that would require the removal of the lens from the body.
bricekin
South Bend, IN
I wondered who nabbed that set. I've been considering getting a non functional set to take apart and do a quad projector retrofit. Great review!
J
JimmyM
Boston, MA
At the price I couldn't resist the gamble.
An HID projector retrofit isn't off the table either. But mine would be a dual projector retrofit with 100W halogen Highs.
But warmer weather is required.
dmm5157
New to the forum, just got these lights for my 2007 Expedition that I bought last month. My old headlight lenses were cracked and the Anzo set was cheaper than buying stock headlights.
Will have to check into the HID projector retrofit. I just took the truck for a roadtrip to Orlando, the headlights performed well for my liking, once I adjusted the beams to the correct height.
J
JimmyM
Boston, MA
The out of the box low beam adjustment is awful but easy to fix. I still want to tweak mine a little. I haven't tried adjusting the highs yet. They need a little tweaking as well, but perform acceptably for now. Over all I'm happy with the upgrade. It won't be until the weather warms up considerably before I get into them though.
dmm5157
I love the way mine came out. Really night and day vs. the ones I had on there before. Installation was pretty easy, took about 15 min total, including soldering the LED wires to the existing parking light wiring.
robertdogul
Gulf Breeze, FL
I also purchased a discounted set if Anzo headlights. They were sold "as new, open box". There were no bulbs in the box but I installed Philips X-treme Vision hi/low beams. The headlights are a huge improvements over stock. I couldn't get the CCFL halos to work, problem was two bad inverters. Vendor sent me replacements and everything is fine. BTW the Anzos cost me $150 on Ebay, I am very happy with my purchase.
J
JimmyM
Boston, MA
Well warmer weather is here. I had to fix a broken plastic post that a metal clip was attached to. I drilled a small hole and epoxied a screw into it and threaded the metal clip onto it. Worked out great.
Here's the bad news. The high beams have no way to aim them, SO I'm stuck with a set of high beams that point a little to the left. The only way to really do anything with them would be to remove the lenses. Just not in the cards right now.
I tested the CCF halos. They work fine and look great, but I haven't had time to permanently connect them. Maybe next weekend. No promises. :smile:
I had the thought of having HID projectors High/Low in the low beam spot and have a pair of round halogen spot lights in the high beam location. This way I could go from true HID low beams to an HID "highway beam" (like a low beam but a little more height to the cut-off and narrower) or with a flip of the switch go from "highway beams" to low beams + 100W spot beams. Just the musings of a mad man.
Flexpedition
midwest
Thanks for the honest reviews and follow-ups. Its unfortunate these offer no high beam adjustment.
SgtStedanko
I know it has been almost two years since you posted this, but I was wondering if you could help me?
I have purchased the Anzo Halo headlights just like you have here. As noted, they come with NO instructions. I have watched a video (or twenty) and think I have a grasp of this, but was wondering if you could shed some light as well.
In the pictures below, I have labeled the wires from a back view of the headlights and labeled the lights from the front view as well so that you can see what MY understanding is.
What I am supposing I need to do, from watching the video(s) is:
1) wire the black wires together from LED set and Halo set and attach a connector (female)
2) wire the green wire from the LED set to the red wire of the Halo set and attach a connector (female)
3) from the parking light on the side, connect a black wire (ground) and a red wire (hot) to the respective wires of that set and attach connectors (male) to each of those wires
4) plug the males and females together and watch the sparks fly (well, hopefully no sparks)
Is this how you did it?
dmm5157
View attachment 18663 View attachment 18664
Sure, I'll take it apart and take a few photos tonight when I get home.
SgtStedanko
I appreciate your willingness to do that, but it is not necessary. I have done a lot of research today and watched that video that was linked above. That all helped and I have the drivers light up and running! I am getting started on the passenger side.
I have been taking lots of pictures and plan to do a write-up tutorial kind of thing once I am done.
Thank you!
PrepVet
Weston, WI
Famn, I like those and normally I hate aftermarket lights.
gixer2000
Retrofit or Bust
Massachusetts
Waste of money in my opinion. Doing a proper retrofit will destroy these as far as performance goes or at least they do in my case
[/URL][/IMG]
dmm5157
[/URL][/IMG]
How much does it cost to replace the cracked lenses? That was my biggest issue with my truck, the spider web cracking was awful. Everything I looked at was more expensive than $250 for a set of Anzo headlights, which took less than 30 min to install.
To each their own, I prefer the way my headlights look. Didn't get them for performance, got them as a replacement for my damaged lenses.
gixer2000
Retrofit or Bust
Massachusetts
The purpose of headlights is for visibility not so much how they look. If you have stress cracks in your lenses then i would recommend buying a oem set from ebay/amazon/junk yard that are broken but still have good lenses, then take 20 minutes to heat and swap the lense over. I see them every day for short money and id take stock over the Anzo all day. I understand the Anzo can be picked up pretty cheap but the output suffers
Not entirely sure what you are showing here...did you modify the stock headlights to install projectors?
Yes, I did! those were the only pics i had in my phone and really are not the greatest but here is a few more so you can understand what i did here
