mohammed
Hello,
in my 2012 ford Expedition XLT 4X4, I have a problem that gave me headache and still, my alternator is outputing 13.8 at best, there was corrosion on the battery terminals and after cleaning it the voltage spike up to normal 14.2v for two or 3 starts.. the I figured OK my battery is sucking alternator voltage in with a new the voltage is 14.2v very good, second run the problem is back,
today tested the engine compartment fuse box, and after test all fuses I found 10 fuses not working they are as follows (according to the manual page 287):
*** UPDATE: I rechecked all engine compartment fuses with engine on and off and took some of them off , results is they are working fine.
I didn't have check engine light !! , Any help is much appreciated.
Thanks
Thanks
