2018 Expedition platinum Max A/C problem
Dgm0rt0n
Lakeway
I ordered my 2018 on Dec 5, 2017. It came in on Feb 15 and that is when I took delivery of it.
On March 12 we turned on the A/C and it just blew warm air. I took it to my dealer that afternoon and it has been there since. They have been unable to determine why it is not working and have gone to Ford
for help. What I have been told is that the A/C installed between early Dec and late Jan (I'm not real sure of the exact timeframe) have problems and the engineers are working to find a fix for the problem.
Needless to say, we are NOT HAPPY! To purchase an $80,000 vehicle, have just 600 miles on it and find out there is apparently an A/C problem that they did not know about (really?) or have a fix for is very hard to understand or accept. This is my first time to put something on the forum, but I think it is something that anyone that has purchased or is considering purchasing would want to know about. I do not have any problem with my dealer... they have been very understanding about my concern. I do have a problem with Ford! I don't want to believe they were aware of this problem, but shipped the vehicles anyway and put
the burden on the dealer to deal with the unhappy customer while the engineers try to find a fix to the problem. Like I just said... I don't want to believe it, but...?
Don
07xln
Dallas
I’m not sure I believe this. Not what you’re saying op but that Ford doesn’t have a fix. An ac system in a car is made up of a compressor, condenser, drier and evaporator, that’s it. The system overall is a pretty simple/basic system. The compressor being the only part with moving parts. When it blows warm most the time it’s a compressor problem. I find it hard to believe they can’t start replacing parts and fix this.
Artie
Georgia
I hope this isn’t a wide spread issue.... we’ve used ours and it works as expected.
aggiegrad05
North Texas
Don
My platinum max (and I believe edizzle’s platinum swb) had a mid-January build date. I have not had any problems with the AC. I know this doesn’t help you, Don, but perhaps it’s a comfort to others to know it might not be a widespread issue.
Flexpedition
midwest
Turning on the AC in the winter and blasting the heat in the summertime is part of the selling dealers PDI process. Even if done inside the shop during winter, any tech can tell shop 73° from R134A 65°. If the truck left the assembly line without A/C, then the selling dealership failed you.
Our salesperson held us held hostage for well over an hour after signing paperwork. He forced us to turn on, turn off, open, close, tilt, connect, disconnect, recline, fold and click every single button, switch, knob and feature of the car. If you all didn't do this, then the selling dealership failed you twice.
deweysmith
Montreal, QC
The computer won't command the compressor on if the evaporator is at or near freezing temps, or if the ambient air temperature is below ~45ºF, so they would have HAD to do it inside the shop, someone might have gotten lazy.
Definitely a dealer failure, though.
Fun fact: the auto climate control will toggle A/C for you as the season changes, and make sure it's on when you need it and off when you don't.
stamp11127
Temple, Georgia
Go to the dealer and check that it has been moved from where it was initially parked. If it has then ask to speak to the tech assigned to it. Ask what has been checked with the results posted here.
drjeff
arizona
Ordered mine in December and took delivery in mid February. A/C works well.
edizzle
Cashiers
Correct, same time period. A/C works swimmingly.
Leigh
Savannah
We received our new 2018 Ford Expedition today and the a/c is not blowing cold air. Had to take back to dealer to have fixed. Apparently, there is a problem with some of these vehicles and ours is one of them. Anyone else experiencing this problem? And do you know how long it takes to fix?
Spoiledhappywife
Arizona
Our build date was 11/17 and no issues. We have hit 100 degrees already.
Wishing you the best of luck.
powerboatr
North East Texas
i love the statements you get from some dealers, "well if it was built between xx and xx there is a problem and no one has the answer...."
bull muffins, a problem didnt appear then magically through the change of dates fix itself.
like eveyone says, its a system with senors and valves, a good tech should be able to follow a trouble tree and fix it.
Dorzak
Don
Did they every get it figured out or is it still at the dealer?
lobsenza
There is an issue with Expeditions (and I think Navigators) built in that time frame. The freon in the A/C system is contaminated. If current A/C evacuaitrron equipment is used to evaculate the system, the A/C evacuation equipment is ruined and the system is not properly evacuated. In order for Ford to fix this problem, they have to devise a way to completely evacuate the AC system. Once the system is evacuated, the entire system has to be replaced (every freon line and all AC components that came in contact with the freon). Since these vehicles have rear AC, the componernts in the rear AC need replacing as well. This requires disassembly of the dash and a chunk of the interior to get the 2 cores form the AC system and all freon lines replaced.
Not a good scenario, but that is the issue. I heard about this from a friend of a friend who has one of the effected Expeditions.
Stout
NC
What's the build date range to watch out for and where does it show the build date?
rcompart
IL
Build dates literally define the window when a problem started with a vehicle line and when it was corrected. It could be that there was a problem with a batch of components, a deviation from a process due to trouble with a machine, a new software revision with an unknown bug or even just simple human error.
Refrigerant contaminantion, while a real thing, isn’t something that I can believe to be an issue here. While it does use the new R-1234yf refrigerant, like the transition from R-12 to R-134a, the service ports are different to prevent the wrong refrigerant from being used and if the assembly plant did somehow manage to have R-134a in equipment for R-1234yf, the two are near identical in system refrigerant weight requirements and operation that the AC would probably work without any noticeable issue.
I am not sure. I think Nov or Dec to January or February.
That’s a huge window to not be sure about. If that really was the case though, it would be such a widespread problem that dealerships would have been made aware of the issue by now and this forum would be littered with ‘my AC doesn’t work’ threads given the last month of high temperatures.
Dormammu
NorCal
Being someone who is experiencing an A/C issue in our new Expy, I'm interested in this thread. However! The only 2 people who personally said they had a problem and posted on this thread posted their 1st forum post here, then have never returned to give an update. Then lobsenza posts his first post ever on the forum in the same thread with what I consider to be a truly terrifying prospect....a serious problem, no current solution and a future solution of ripping the vehicle apart, but with pretty vague details.
So Lobsenza, if you could provide more info, that would be great. Is your friend in Texas same as you? Where in Texas? Is this person a member of this forum? Would they be willing to come on and give some additional info? The build dates affected, the dealer they are working with? Do they have a Ford representative they have talked to? Are you on the Expy forum because you own an Expy? Wanting to own an Expy? Interested in helping with an AC problem? I'm concerned you will feel defensive and interrogated which is not my intention. I have an $80,000 truck with just over 2,000 miles on it and an A/C problem and I'd like more information if you're willing.
Mike Wolfe
Tonopah AZ
Our EXPY was built 01/22/2018
Was purchased by us 5/21/2018
It was built at the Kentucky assembly plant
Has the Auto HVAC system & living in AZ it has been thoroughly & severely tested.
It has been 115 degrees for the last 3 days & still will cool so well that MAX AC is too cool in a short time after start up
As a retired engineer it is hard for me to believe the dealer could not correctly diagnose your non functioning system in a few short minutes
If the compressor is running then a check of low side & high side pressures will tell if the refrigerant is correct & what the evaporator temp is
If the evap pressures are correct then a check of the blend doors will confirm if the system is adding heated air when it should not
Not rocket science here
Really wonder about the competence of the dealer here
If I were you I would be contacting FORD directly
Their number is listed in the owner's manual
While I am not familiar with the newest refrigerant, one thing is for certain.
The low side pressure directly converts to evaporator temperatures
with R12 if the low side pressure was 45 psi then the evap temperature was 45 degrees F
I believe that 1234yf is about the same
If the ambient air is at 100 degrees F then the system pressures when stabilized & at rest should be 100psi for both the high & low sides
I am pretty sure that FORD uses a dual displacement compressor
The compressor uses full displacement mode under the MAX air setting & a lower displacement under normal cooling conditions
Just checked the AC label on our vehicle & it does use the 1234yf refrigerant
Charge size is 2.31lbs which is very small compared to the old R12 systems
It has the rear AC system as well
The statement that all vehicles built from DEC through Jan 2018 must be incorrect based on the fact that ours works very well
should not be that hard to get HVAC system issues corrected if the dealer has a competent well trained AC Tech:33:
