ForScan Tweaks - 2015+
17LimitedExpy
TN
Any negatives with Navigation in Motion? There are some cautions about stuff that might be affected.
-- Chuck
Chuck,
I've been running with the Nav in Motion for the last 2 months...my wife and I volunteer with Mobile Meals and it makes it very easy for her to enter additional addresses while I'm driving to the next destination...which by the way for everyone's info, you can have a max of 5 waypoints and 1 destination at any one time.
As far as "drawbacks" for the Nav in Motion feature:
You lose 911 automatic call-assist (see Loki's response above on how useful it may be)
You lose Sirius Travel information such as weather, fuel prices, etc.
The Speed Limit sign displayed on your Nav screen is round (not square/rectangle) with a read circle around it (it's the EU standard speed limit sign)
m3olsen
CNY
Thank you 17LimitedExpy. First: I tried the link again and it works fine - takes me to the page where you enter your VIN. Not sure why it didn't work for me before - as I mentioned I tried across multiple browsers and wasn't getting there, but it works now. Perfect.
Second: yes would love to know what those further changes are to enable DRL option in left cluster to work - would make my day. ;)
Third: I will certainly keep an eye out and report back anything I find. Thanks again for the help.
17LimitedExpy
TN
To the keeper of the FORScan Codes-Expedition spreadsheet...
Thank you,
And please add a "Last Revised" or something to that affect, to the top of the spreadsheet.
Dennis
Dennis - the sheet located at the links throughout this thread is the most current spreadsheet at all times...but I've now added a date at the top of the spreadsheet on the 15-17 tab. When you get a chance, take a look at the link below and provide me with feedback if this is what your looking for...thanks.
https://docs.google.com/spreadsheets/d/1iO4Uz1shNRwZv5gi2TKARDo2Y7lfSOMFj6Gott8g7yg/edit?usp=sharing
Dennis48755
Caseville, MI
17LimitedExpy,
Perfect, thank you.
I understand the link opens the latest updates, however I prefer to download the spreadsheet into Excel to use it in my garage (out of Wi-Fi range). I also like to keep older versions and by your including the revision date, I can add that date to the file name. Previously I included the download date but had no idea if you had made any changes/updates to the file.
Thanks again,
Dennis
Amacron
Louisville Ky
For the life of me I cannot download the link. Keeps getting an error stayed page had to be reloaded but then nothing happens??
Super Moderator
Super Moderator
I get a similar Error from Tapatalk on my iPhone. Wonder if from a desktop browser it will work?
Eagle72069
Evansville, Indiana
anyone know how to adjust the amount of light or should I say lack of light to make you headlights come on? I am finding it is way past dawn when my lights finally turn on, and since I have a black vehicle it is a matter of safety at this point.
tbone1004
Greenville, SC
Saw the horn off on lock in this thread, somehow mine got disabled the search function is failing me. Any help on which module I need to change to get the horn on lock back? i thought it may have went away when I turned the double honk when key is out of the car, but hoping you guys can help me
m3olsen
CNY
According to the shared spreadsheet, toggling horn when locking doors with key outside is in the BCM. If you referencing some other horn function, please quote the Post number in this thread - maybe I'm missing it but not seeing any other horn function in the spreadsheet. If you are really stuck, you should be able to load your factory defaults and get back to where you started.
HockeyPuck99
Frisco, TX
Tbone1004, I assume you mean the double honk when you lock your doors with the key fob. If so
The Module is BCM
Line: 726-16-01 xx?x XX
Change the "?" to 0-for Disable or 1-to enable the honk.
Once you make this change you'll have to manually turn back on your auto running boards if you have those. That is done in the left menu in your dash.
I hope this helps.
