stamp11127
Only problem with replacing the hub is the caliper will hold the rotor and hub on the Expy.
If the wheel stud isn't spinning in the hub the easiest method would be to drill out the studs on the broken nuts - but not larger than the stud hole.
The remaining nuts I would heat up with a propane torch.
