fastcatexpress
have a used used 97 5.4 engine with 85k on it trying to deside weather or not to change out timing chain and tensioners and guides? before droping it in my 97 expedition. oil look kind of dirty in it !
Why would you change out parts that normally last 200 thousand miles? You could pull the timing cover, inspect the chains, guides. If OK, replace timing cover seal, and gasket. I would as Stamp stated, change valve cover gaskets before installing, along with new Motorcraft sparkplugs. Much easier to do now than later. Other than that, have at it!
Habbibie if its really 85k that's just changing parts to change parts. That's why I said pull the cover, check for slack. If that mileage is for real it should be a virgin in there! If not whoever sold the motor, lied his ass off to sell a motor!
+1 I have 211k on my 5.4L. Timing chain isn't on my list of things to worry about because I change the oil. The Mustang I bought and ended up building with my son for his first car; however, is a different story lol Like these parts? Same thing, only different... We bought it this way from a girl. Rapping like Run DMC.That engine's young at 85K. They normally go well past 200K with good oil changes.
20170324_181354 by Dave H, on Flickr
20170324_160843 by Dave H, on Flickr
Mustang timing chain small by Dave H, on FlickrDefinitely. The girl who owned this one destroyed it. Three spun bearings and a bunch of other issues I had to straighten out. After working on this one I fell in love the Mod platform. Very easy to work on. The only thing I didn't like was the twice the price cams... Can't do much about that on a twin cam motor though I suppose lol All I had to do was hone the cylinders. No other real machine work after all that abuse. How do you beat that?Trying to find a high performance car like a mustang or Camaro, that hasn't been beat like a field mule is tough. Factor in a lazy maintenance schedule, and you have usually a trashed motor. Luckily the 5.0 and 4.6 mustang motors are tough.
I never was into the old 5.0s and the 351s in my old F250s never gave me much of a hassle thankfully. I was always ripping around in Z28s etc. when I was younger. I mainly stick with messing around with my 69 bbc Camaro now if I'm working on something for fun. You want to see bullet proof? You should get out the Gen 6 big block Chevys. I just built a 461 that started out as a 98 van 454. 4 bolt main roller motor from the factory.I personally like the earlier fox motors. 5.0/5.8. it's amazing the punishment they take. And with some simple hotrodding you can easily eek out 300-325 hp. More if you dont care as much about reliability.
From what I gather it’s the valvetrain in the big blocks that don’t like the higher rpm
Chevy motors are tough, as long as some bonehead used good parts. The big blocks are tough too, but because they are big blocks can't be spun too high rpm. I've always liked torque of say a 427 or 454 mill. A friend years back had a 65 Gto 389 built up, what an animal that little goat was! Wasn't going for a pun, but guess I did.
