Before swapping to LED bulbs (or after), if you have a problem with the quality of the lights be sure to tell your dealer that they are not bright enough. Make them work on it, adjust it, whatever. Then tell them that it still isn’t acceptable at night. Then put in your led bulbs. We need a history of complaints with ford and nhtsa for anything to ever be done.
The cutoff is the same with aftermarket leds but they are much brighter to start with so it’s better.
As for someone with factory leds not happy with the brightness, there is no upgrade option, you can’t just swap bulbs on those, it’s an entire module.
