static after shut down took about just a few minutes if that long to bring both sides down, iirc it was around 60 on both sides, but i didnt log it,
it was equalizing, then if i restarted it ran in the range , took a minute to get to 44 , it would get to 40 pretty quick then slowly move up. The high side really stayed pretty steady within the range by the chart, 160 was the high for the event, that why i logged it. the range was 150 to 170 for temps. the temps though i question, as it was most certainly hotter around the area. the 0ver 400 was when the compressor shut off, it just sort of climbed slowly , then held , then dropped immediate once compressor was called back to run. the switching is at the drier which controls the condenser fan and the clutch engagement
it was really very smooth and no huge pressure jumps, just making cold air
actually it was SMOOTHER than it ever ran since 2009. that may sound weird, but the it was very stable and no weird behavior. no pulsing of hoses, no weird vibrations, no weird noise
the tx valve got cold and frosty the low side got frosted, then the clutch would be called to shut off and the two would defrost.
