If you are using a new module, you will have to program both lines of the HSWM to the following:
HSWM 714-01-01 ?000 0000 xx (the xx is the checksum and you don't change it, FORScan will change it automatically for you)
This line of the module controls how long the HSW will remain on. Here are the codes for duration:
Change ? To: 0-Disabled (Default-HSW stays on until you turn it off), 8-5 minutes, 9-10 minutes, A-12 minutes, B-15 minutes, C-18 minutes, D-20 minutes, E-25 minutes, F-30 minutes
Initially set the code to A, then write the line...later you can change it as required. (FORScan is set to initially recognize this line as 714-01-01 A000 0000 xx) NOTE: I have mine set to A=12 minutes and it works perfect
HSWM 714-02-01 02?? ???? xx (the xx is the checksum...see above)
This line controls the Internal Temperature of the Heated Steering Wheel
Change the ?'s to the setting of the Heated Steering Wheel you are using...I have a 2016 Explorer steering wheel, so I changed the ?'s to 5C 5C5C...this is the default setting of 92F for the 2016 Explorer steering wheel. You can change the setting to warmer, but you will shorten the life of the heating element in the steering wheel, so be careful.
Other settings for the Temperature are to change the ?'s to:
44 4444 = 68 (13-15 Fusion/MKZ default), 4C 4C4C = 76, 54 5454 = 84 (Mondeo Default), 58 5858 = 88, 5A 5A5A = 90, 5C 5C5C = 92 (16-18 Fusion/Explorer Default), 5E 5E5E = 94, 64 6464 = 100 (16-18 MKZ/MKC Default)
My module looked like this after I programmed both lines:
