Heated Steering Wheel - Installation on my 2017
East-TN
East-TN
Air Force
TN
Next, do a scan around the interior to make sure you have everything reconnected, zip-tied, secured, cleaned up, etc.
Reconnect the battery to the vehicle.
You are ready to program the Expy to recognize the Heated Steering Wheel Module (HSWM) and setup your new heated steering wheel.
East-TN
East-TN
Air Force
TN
But, before I started any programming I wanted to ensure the wheel was connected properly and operating as I had expected...so I started the Expy and tried the various switches on the steering wheel to see if/how they worked.
I then took the Expy for a short drive to test the cruise buttons/functions.
Once I was happy everything was working as I expected, I returned to home and shut off the Expy...ready to program.
East-TN
East-TN
Air Force
TN
Once you connect your vehicle to FORScan, select/make a new profile when reading your vehicle (if you don't, FORScan may not search for the new HSWM you have connected).
When FORScan reads the modules in your Expy, you should see something along the lines of 'Found Module: HSW Heated Steering Wheel'
I recommend you make 3 changes to the modules in your Expy:
1. Change the APIM to display the Heated Steering Wheel icon on your display
2. Change the IPC so that you will have the option to turn on the Heated Steering Wheel when you remote start your Expy
3. Change the HSW Module to reflect the settings you want
In the next post I'll go over each of the 3 recommended changes to explain what you are looking for.
star-art
Pacific Northwest
Fantastic, thanks!!!
My only concern is choosing the circuit for tapping power. I don't know how much current the heated steering wheel element draws, but electric heaters tend to demand a lot of amperage. I also don't have a wiring diagram for an Explorer, but the diagram I do have (for a 2016 Focus RS) shows the HSW element is connected to its own dedicated 15A fuse. The power circuit you tapped is 10A and is shared by several relays. I can't imagine those relays require much power, but I'd just want to make sure the circuit can handle the extra load.
Also, the HSW element connections for the '16 Focus RS are 18 gauge wire. I'd also want to make sure all connections for the heating element are at least that size.
This Lucas fellow you mentioned who makes a wire harness for the F150 upgrade, how do we reach him again? You may have posted about that before, sorry if I missed it.
Thanks again! :)
East-TN
East-TN
Air Force
TN
Post #30 gives the contact info for Luke, but here it [email protected]
Again, ensure you mention to him the harness you want is for the Expedition and he will make you the correct harness (and it saves you $50).
I understand your concern about the fuse size. So far I haven't had any issues, but I haven't used the HSW too much yet :)
If I run into an issue I'll post up my correction...and hopefully, so will anyone else who does this modification.
haviland
MA
17LimitedExpy, you are one awesome individual. I just got finished looking at the step-by-step instructions you posted. I got tired just looking at all those steps!
For anyone looking to install that heater, you made it seem certainly doable.
hueyf4i
US
Heated grips on a motorcycle I understand, but a heated steering wheel on an SUV[emoji848]
One thing I wish I could get on my motorcycle would be a air conditioned seat.......
Sent from my SM-G955U using Tapatalk
East-TN
East-TN
Air Force
TN
Not sure what part of the US you live in, but in some areas it gets a little chilly and when you park your Expy outside overnight or for long periods of time...it's very nice to have a heated steering wheel.
I just used it the other day when the temps in the morning are dipping into the 50's...it was great on the hands! When the temps reach the 30's and below, it will be one of the best Mods I've made to my Expy!
hueyf4i
US
I actually hadn't thought of a heated steering wheel before I saw this post. I live in Virginia, we're only into the 50s overnight right now, but we'll be in the teens in December. I've been fortunate to have remote start on my last 3 vehicles, but a heated steering wheel would be tempting without it. I have the bonus of the black interior in my truck too, so as long as the sun is out I get a heated steering wheel and dash for free.... lol
East-TN
East-TN
Air Force
TN
Use FORScan to change the APIM so it will display required soft buttons on your Center/Nav display screen:
Sync 3 - Climate soft buttons on screen
APIM 7D0-01-01 xxxx xxxx x?xx
Change ? to:
1=Heated Seats, 2=Heated/Cooled Seats, 3=Heated Seats/AC, 4=Heated Steering Wheel, 5=Heated Seats/Steering Wheel, 6=Heated/Cooled Seats/Heated Steering Wheel, 7=Heated Seats/HSW, 8=AC/Rear Controls, 9=Heated Seats/AC/Rear Controls, A=Heated/Cooled Seats/AC/Rear, B=9, C=AC/Rear/HSW, D=Heated/AC/Rear/HSW, E=Everything
I changed my APIM to an 'E' so that I would have Heated/Cooled Seats Icon, the HSW icon, and maintain control over the Rear Temp Controls.
My screen originally only had the Heated/Cooled Seat Icons like this:
After I changed the APIM to 'E', my screen now had the HSW Icon like this:
East-TN
East-TN
Air Force
TN
With FORScan, change the IPC module so you can select the HSW option on Remote Start.
Heated Steering Wheel - On with Remote Start (Provides the option in the Left Instrument Cluster to enable the HSW to come on when you start Expy by Remote)
IPC 720-02-02 xxxx x?xx
Change ? To: Add 4 to the existing value at ?...example, mine had a 9, so + 4 = D, or if you have an A; change to E and so on
Once you make this change, you will be able to navigate through the Settings pages on the left display of your instrument cluster to select when/if your HSW will come on during Remote Start...like this:
East-TN
East-TN
Air Force
TN
When you select the 'Seats & Wheel' setting you will have the option of this:
East-TN
East-TN
Air Force
TN
Last Module to program is the Heated Steering Wheel Module (HSWM). When FORScan reads the modules of your Expy, you should see this:
East-TN
East-TN
Air Force
TN
If you are using a new module, you will have to program both lines of the HSWM to the following:
HSWM 714-01-01 ?000 0000 xx (the xx is the checksum and you don't change it, FORScan will change it automatically for you)
This line of the module controls how long the HSW will remain on. Here are the codes for duration:
Change ? To: 0-Disabled (Default-HSW stays on until you turn it off), 8-5 minutes, 9-10 minutes, A-12 minutes, B-15 minutes, C-18 minutes, D-20 minutes, E-25 minutes, F-30 minutes
Initially set the code to A, then write the line...later you can change it as required. (FORScan is set to initially recognize this line as 714-01-01 A000 0000 xx) NOTE: I have mine set to A=12 minutes and it works perfect
HSWM 714-02-01 02?? ???? xx (the xx is the checksum...see above)
This line controls the Internal Temperature of the Heated Steering Wheel
Change the ?'s to the setting of the Heated Steering Wheel you are using...I have a 2016 Explorer steering wheel, so I changed the ?'s to 5C 5C5C...this is the default setting of 92F for the 2016 Explorer steering wheel. You can change the setting to warmer, but you will shorten the life of the heating element in the steering wheel, so be careful.
Other settings for the Temperature are to change the ?'s to:
44 4444 = 68 (13-15 Fusion/MKZ default), 4C 4C4C = 76, 54 5454 = 84 (Mondeo Default), 58 5858 = 88, 5A 5A5A = 90, 5C 5C5C = 92 (16-18 Fusion/Explorer Default), 5E 5E5E = 94, 64 6464 = 100 (16-18 MKZ/MKC Default)
My module looked like this after I programmed both lines:
East-TN
East-TN
Air Force
TN
If you have a Used HSWM, then program the lines in the module as you require/desire...always be careful about setting the temperature hotter than what the default setting is for the steering wheel you are using.
Setting the temp to hotter will shorten the life of the heating element in the steering wheel.
I have my 2016 Explorer steering wheel set to the default of 5C 5C5C (92 degrees) and it gets very warm/toasty...almost too hot. After this first Winter of using the HSW I may revisit this Temperature setting to adjust to a slightly cooler mode.
East-TN
East-TN
Air Force
TN
You should now have a nice Heated Steering Wheel installed and functioning in your Expy...an option Ford should have had available, but you will now be able to utilize/enjoy.
And you will have a very uniquely mod'd Expy to boot :) Currently, there are not many 2017s on the road with this feature.
This mod will probably work very easily on 2015 & 2016s...please post back here when you try it.
Modding a 2018 appears to be even cheaper...it looks like the 2018 F-150 steering wheel is the same for the 2018 Expy...you will still need the HSW, HSW module, wiring harness, and HSW clockspring, but at least you could save some $$ by using your Expy airbag. Please post back if any 2018 owners update/upgrade their non-HSW Expy's...I know the HSW is an option on the 2018 and up Expy, but I'm sure not everyone selected that option when purchasing.
star-art
Pacific Northwest
This is AWESOME!!! THANK YOU SO MUCH! I am looking forward to doing this mod on my truck. (Also, rain sensing wipers.)
BTW, we had a 2016 Explorer Platinum and I agree the heated steering wheel would get pretty toasty. Perhaps a setting of 88 or 90 degrees would be perfect.
PS Perhaps the one last thing that's needed to make this swap perfect would be custom circuit boards to fix the steering wheel buttons. . .
East-TN
East-TN
Air Force
TN
Update: I’ve used my heated steering wheel several times since the temps are getting into the upper 20’s/lower 30’s. The wheel temp of 92 that is the factory setting for the Explorer is very good. The wheel gets very warm during the initial on time until the max temp is reached, then goes into a cycle mode to keep the wheel very comfortable.
Bottom line; I’m going to keep the stock Explorer wheel temp setting...it’s the right temp for those colder days.
creef14
VA
Anyone tried this mod with one of the 2019 expedition heated steering wheels?
I was also wondering if the f150 raptor wheel could work too...
