34Ford
Wow, I didn't remove the cross member, mount or drive shaft to do my 07. Did removing that stuff make it any easier? I only had my bottom rear break and it was just a little under flush with the head.
The reason for having to remove cross member and tranny mount, plus unbolt driveshaft was that damn orange hanger mount you see riveted to the trans mount.
The one on the left is 2 piece so it opens. But the right one is solid so there is no way to get the cats down low enough to make room for the manifold to come down from its home.
Oh and I forgot the starter had to come out as well. The top bolt on it was a royal pain, you cant see it from the bottom so its a feel thing. You must have, ratchet extensions and a swivel joint.
And I broke a 5mm socket removing the studs.
