Solution for frozen locks?
what about keyless entry via keypad or fob?
that doesnt open door either?
Nope, that’s why I made the thread it was frozen and neither my fob or key unlocked the door. That night was a soaking rain and next morning it was all frost and ice.
Plati
I must admit multiple issues with these doors (not latching, not unlatching, locks frozen closed, etc) all with different issues .... Lots of parts in there and different designs for different years! Way over my head.
I went to the "door lock actuator" idea partly because the passenger door doesnt have a key like the driver side, so spraying lubricant inside the key mechanism isnt an option on that door. If it aint the key on the passenger door, probably isnt key on driver door either?
And (me not really knowing) the "door lock actuator" isnt the latch mechanism, maybe it just prevents the latch mechanism from releasing/opening so door would stay closed? Sort of the reverse of if it got stuck and prevented latch from engaging (problem where door doesnt latch closed like on mine).
When its frozen & door wont open ... and you hit it with keyfob ----- does that pin at top by the window travel up & down or is it stuck in the lock position also? Like it shows at start of video.
Maybe this is a stretch but another problem in rain/frozen is actual ice freezing the door to the body (rubber seals and such) where you have to break the ice keeping door closed to get it open. I suppose you lock the door every time so you know it isnt that.
When my door wont latch and stay closed ... I can get that problem solved by cycling the lock mechanism using the keyfob. A few lock unlock cycles and the door will latch closed and stay that way - so I know there is an interaction between the lock actuator and latch.
My head is spinning now!
Moderator
So much to say, so little time!
Mr Sticker - Most likely you have a door alignment issue. You door is most likely low or right because of a worn hinge. The latch on the actual door frame can be loosened and moved small distances to align. The latch can’t close around the bar because the weight of the door is preventing it. Locking and unlocking moves it slowly to the point it can close(This is REALLY bad for the actuator and mechanism). Take it to a good body shop!
All Expy’s have external keys holes on the Driver door, just the keyless models are covered up behind plastic. That serves one purpose. It insulated the metal from the elements and moisture. That helps to prevent ice lock in the actual mechanism.
The sprays like I suggested above help with that condition by coating the metal and preventing the ice from forming! That same spray can be used on the actual mechanism on the side of the door, but long term a good grease is also suggested. That lubricates the mechanism and prevents water from staying around.
Plati
I appreciate the discussion & feedback. I however disagree that the problem with my 2003XLT driver door not latching in extra cold freezing weather is door alignment. Its clearly only during a deep freeze (5 degrees Fahrenheit or less) and almost always every year - just the first couple big freezes of the winter for some odd reason. Alignment seems spot on and owned since new. I seem to recall that I can observe the latch staying open even after closing door and door fully seating against body but latch not latching so it just bounces off. PITA! Of course I could be wrong, everyone can always be wrong. I know that.
I'm a big fan of lubricating anything and everything including locks. My "go to" fluid for lock mechanisms is this graphited fluid. Have used it (sparingly) on the ignition switch, door keys, and various master locks that are outdoor. Gotta spray it and work the mechanism to get it distributed all throughout. The trailer tongue ball lock on my snowmobile trailer is a great example of how well this works in a full winter outdoor environment. There are a lot of other products too, most good - all better than nothing. Although I personally would not put Fluid Film in a lock, too gooey. I have some locks covered in plastic shield that keeps all water out. Grease is good on many parts on the Expy also, especially the non water soluble grease.
Moderator
You never said it only happened in the cold, just that it didn’t latch...if you did, then I missed that.
The latch is mechanical, so if it isn’t latching in winter, then my suggestion is next time it is warmer, clean the latch mechanism REALLY well with a solvent. Personally I would use WD40, and remove all grease/grit/Dirt and then degrease it. Then grease it again. Exercise the latch many times during the process, both during cleaning and greasing. See if that takes care of your issue. You might have a burr or dry spot somewhere, and when the metal contracts it gets too tight to allow movement. Still think door alignment could be an issue. It might be that the latch bar isn’t fully depressing the release when it is cold. Just ideas...
jeff kushner
North of Annapolis
The nicest thing about a remote start is that you can warm up the car and de-ice the windows before you get in it. Really appreciate that stuff in the dead of a 10-degree New York winter at the seashore.
I bought my sweetheart "remote start" for her Rogue for Christmas last year but had it done in early Dec and she is still thanking me every single cold day....talk about a return on investment!
R/
Muddy Bean
Loki,
The doors not latching in cold weather is actually a thing with these trucks. My 2015 doors will bounce back open when you close them in really cold weather. I’ve had all my doors do this only on the Expedition. I’ve never had it happen on any other vehicle. Huge pain to unthaw them with a mini torch so I can close the doors and drive down the road. They recalled F150’s for it but have yet to do this for the Expedition. https://www.google.com/amp/s/amp.usatoday.com/amp/775137001
Plati
Loki,
When this happens with my 2003 Expy .... I cycle the electronic door lock a few times, maybe the handle, open & close it in between and I can get it to latch. Once I discovered this it has worked every time. No guarantees it will work for everybody.
Thats a LOT better than using the seat belt to keep the door from flying open, or tying a rope between the two front doors, or other solutions! The worst is when you dont know the door hasnt latched until you drive around a corner & the door swings open:eek:
I really think this is caused by the door lock actuator but Im not going to replace it to find out. Maybe someone else knows?
Moderator
Loki,
Never had the issue with our 15 or our 17. Had it with VW’s in the past. Cleaning, lubricating, and protecting the assemblies helped/solved them. Again, original message did not mention cold, just not latching, which in general is caused my misalignment.
Still think somebody that is having the issue on a day above 50, clean, degrease, and degrease and see if it takes care of the issue.
Moderator
Loki,
Also, they aren’t replacing the latch, they are installing water shields, and replacing linkages if bent, and cables if broken. Again, lending to the theory that a good cleaning, and regressing could help for 2 reasons. To lubricate and make it move smoother, and to prevent water intrusion.
Muddy Bean
True, I just have had this issue last winter in really really cold weather even when lubed my door latches would freeze open and wouldn’t latch so you couldn’t close the door. At that time I had 60,000 miles on my truck. I have never ever had this happen to any of the 26 vehicles I’ve owned and driven in the cold of Michigan winters so it was a definite surprise. I ended up spraying it with deicer spray and that solved the issue temporarily. I’ll be wintering in Florida this year so I am not worried about it at the moment :)
ManUpOrShutUp
I remember the days of frozen locks when I lived in the suburbs. We don't lock our vehicles at home these days though as the house is a good 35 yards from the road. Back in the day though, I used to carry the keychain lock deicer.
