G213
After some poking around and using some old gift cards...I’ve found three different rear wiper/arm combinations you could choose to use on your Gen3. (These may work on other generations, but I’m not sure) Maybe you'll want to try a different style on your truck.
Factory - Snap On Style
Arm Part Number: 9L1Z-17526-A
Blade Part Number: WW1612
This was the style my Expy came with; the blade snaps into the arm. This appears to be the style used for most of the Gen3's. When I first attempted to change the blade, I snapped the arm by mistake. Not a fan of this design. This arm lifts a couple inches away from the glass.
Factory - Slide On Style w/ Release Button
Arm Part Number: 9L1Z-17526-AA
Blade Part Number: WW1614
It looks like this was the style used on 2017s before the design change. This is what I’m currently using. I like this clean look, but it's best for warmer climates; works great for water but not the best for snow and ice. Note that this arm doesn’t lift more than an inch or so off the glass, which makes winter scraping difficult.
Aftermarket - Metal Arm and Bosch Icon Blade
Arm Part Number: Dorman 42651
Blade Part Number: Bosch Icon 13A
This was the style I used before I finally tracked down the part numbers for the slide on arm and blade. This would be my choice if I lived in a colder climate; I’ve run Bosch Icons since they came out, they perform great in snow and ice. This arm lifts a good 4 inches away from the glass, making scraping and snow removal much easier.
Other blades will fit this aftermarket arm as well, as long as they are 13 inches and support the hook-style connector.
