cruise control
Vicksburg, Mi
Should my 2001 have a indicator light come on on the dash when the cruise is turned on? My cruise doesn't work and I have checked the fuses and changed the sensor on the master cylinder. My thought is the problem is in the steering wheel because when I check voltage at the cruise module I don't see 12 volts when I hit the on button. Thoughts anyone?
stamp11127
Temple, Georgia
Wiring diagram for cruise and cluster. Be careful around the airbag or you will need to change your pants if it doesn't kill you.
  • 2001 cruise control.pdf
  • 2001 cluster.pdf
and0r
CA
no indicator light
throttle driven, oldschool
the cruise cable is attached very firmly to the throttle body,
there should be no play
chances are your throttle cable is also warn
check that
Plati
Yes there is a Cruise Control indicator light by the speedo, look in the Owners Manual
1955moose
My 2000 lights up when the cruise is flicked on. Like stamp said, read up on how to not set off air bag, and test steering wheel switches. We'd like you back with a progress report!
and0r
CA
Yeah my 99 lights up too.. idk why I thought it didn't
Plati
The light was hidden by Spiders
and/or
You were thinking no indicator light on the buttons
:cool:
Vintageracer31
Vicksburg, Mi
I did the button diagnostic and the only time the indicator light came on was when I pressed the off button at the beginning of the test. That indicates to me the problem is in the steering wheel or column
stamp11127
Temple, Georgia
You have to be very careful testing the control switches if you probe the connectors. If you look at the first diagram the resistances are indicated for each cruise setting.
Warning: If you apply power from a multimeter to the airbag by mistake - BANG. Bodily injury or death will result if your in the way. At a minimum you'll crap your pants.
If you do this test make sure you take readings on the right circuit.
I remove the airbag then probe. Carry it facing away from you.
Goff69
