Power foaming a 3.5 ecoboost
Nevin
Iowa
Hey all, its my first post here on the forum. Just bought a 2015 expedition El the other day with higher miles (its all highway, i have spoken with previous owner) and was wondeeing abiut doing something like amsoil power foam to clean the valves and intake what with the motor being direct injection and all.
However I do see a maf sensor on top of the intake manifold and I know the foam stuff is not sensor friendly.
Any thoughts or tips? Recently did it on my 99 f150 with great results. It has 154k. Oddly, my 2015 ecoboost actually has MORE miles, lol
I did a search for "power foam ecoboost" on here and didnt really come up with much useful.
Sorry if this is a common question.
Also i want to flush the tranny and I did work in a shop for 10+ years so i have plenty of tools and i have flushed other trannies but I no longer have access to a tranny fluid exchanger. Is this the kind of thing i can do in my driveway or shouls i take it to my local shop?
16plati
VA
Owners manual states take it in for tranny service. You have to decide if you want them to do it the right way or you “think” you’re doing it right and screw it all up.
DO NOT USE FOAMERS OR FUEL ADDITIVES!!! Cannot stress this enough, you will be making a very expensive mistake. Best thing to do is get yourself an oil catch can (JLT for instance) and every now and then hit her WOT up to 100mph to clean the valves. It’s not my truck, but I would never put any fuel or foam cleaners in an ecoboost, ever
N
Nevin
Iowa
Yeah i was looking at a catch can or something. I used to run subarus and air oil separators were quite popular. It was one of my favorite mods. Does such a thing exist for the ecoboost? Thr hoses from the pxv fed to a piece that threaded into the oil fill and the old vapor would drop right back into the oul and you would never lose a drop or get oil in the intake. I really should take my intercooler off and clean it out too probably.
And why no additives or thibgs like that? Just an honest question.
And like i said, i have flushed many trannies before the correct way with a machine but havent looked in there yet to see what style connectors and everything it is.
N
Nevin
Iowa
And im sorry for the typos. My phones autocorrect is very awful. Thanks foe the swift reply.
And the reason about asking about the power foam is simply because since i already have high miles im sure the buildup is already there.
A catch can is fine to fend off future buildup but its not going to undo what is already there. What are my alternatives?
Edit*
Also i cleaned the maf sensors the other day and noticed the oil buildup inside the intake manifold, thats what made me think of it in the first place.
16plati
VA
Edit*
Google sea foam ecoboost, I’m sure you’ll find plenty of reasons why not to. Ford specifically states by tonise any of that type of stuff bc of potential damage to internal parts. Why would you want to do something that they specifically say not to do? You’re better off just going the oil catch can route with 5000 mile full synthetic oil changes
N
Nevin
Iowa
Sea foam and power foam are not the same, i think you may be mistaken. The amsoil power foam is made to spray into the intake while the engine is running and then you shut it off and let it sit on the valves for 10 to 15 minutes then run the vehicle again.
Im not going to just go do it right now and ignore what youre saying, but im just asking what IS the correct way?
CRC makes a product specifically for cleaning gdi engines.
16plati
VA
Like I said, no foam should be sprayed in here. Ask your dealer service tech
16plati
VA
There is no correct way, 5000 mile oil changes, catch can, and drive it like u stole it every now and then
16plati
VA
I’m not gonna tell you what to do tonyor own truck, just keep this in the back of your mind when your putting that foam in there
Moderator
MANY and I mean MANY have used the CRC brand Intake cleaners on Ecoboosts with positive outcomes.
I have helped several people with High Mile EB 150’s do it and it made noticeable difference in performance of the engine. Helped one with a rough idle. Another’s MPG went back to where they expected it to be. All positive.
Use it, follow instructions from the video and the can, and you won’t have any issues.
N
Nevin
Iowa
Thanks for all the replies.
That video that you sent was one i was thinking of. I have never been steered wrong by any CRC product.
Also my mileage was nearly 21mpg on the screen bringing it home on the 80 mile trip from the dealer. And its been 18.5 or so dricing around town.
16plati
VA
If anything use their MAF sensor cleaner.
Moderator
The MAF Sensors in our trucks have very little chance to get dirty. I have seen some with 140K, and NOTHING on them. If your Air filter is doing its job, no issues there.
The CRC GDI cleaner works. I have seen it for myself. My experience has been on 150’s, but we have the same first gen 3.5TT that was in the 150 for years so it will work.
16plati
VA
Well they aren’t MAF sensors, they are MAP sensors. There are three of them, and the one on top the manifold is going to be dirty from the blow by unless you have a quality catch can
16plati
VA
Also, I own two expeditions, one modified and one bone stock. Both 16s. Both have had build up on the manifold MAP sensor since I purchased them (now both above 40,000 miles) so your statement about ones with 140,000 miles isn’t really valid. These things are constantly being blown with oily residue, just go look at f150forums if you don’t believe me.
Moderator
Woohoo, 2. I also own 2 EB’s, and this is my 2nd EB Expy, 4th EB overall. I have worked on Many EB 150’s. In comparison to older Fords like the 4.0L, 4.6, or 5.4, I see the MAF Sensors as much cleaner. But that has been my experience. It is all relative.
Either way the CRC cleaner works for the intake, your doom and gloom about it, is just not founded. Ford not recommending something that relatively easily helps a problem that they ended up solving on the 2nd gen 3.5TT EB by adding Port injection back. The other option is a tear down. The CRC just seems like a no brainer.
TobyU
"them to do it the right way" You give them way too much credit.
16plati
VA
In reference to a transmission fluid flush and refill seeing as how there is no dipstick to check the level yourself
jeff kushner
North of Annapolis
I know that sometimes the "newer guys", regardless of their own talent level, don't know whom the "resident guru's" in a given forum are. Those "gurus" are not self appointed but have earned their place over time by helping others. Loki is one of those when it comes to all things "computer related" in these trucks(& others)....just a FYI for you....
jeff
