OEM Raptor Wheels and Tires
MATT0404
NW PA
I picked up a set of Raptor take-offs today. While my ReadyLift 3/2" is in the mail, I couldn't resist the urge to test fit them with the stock suspension.
To my surprise, they fit pretty well all around. The front tires rub the inner fender liner but only at full lock. The rear passenger side made contact with the fender liner as soon as I bolted it up. Nothing a little ingenuity couldn't solve (see below). The driver's side rear didn't rub at all. The 17" wheels clear the calipers and lower ball joint just fine. Tires fully clear the upper control arms.
Once the lift is installed I expect all rubbing issues to be resolved. I didn't (and won't) be testing OEM suspension articulation with these installed. I'd guess it would reveal other rubbing issues, but for day-to-day driving on paved roads, there's really no clearance issues as long as you avoid full steering lock.
I'm loving the look and can't wait to lift it! Unfortunately, while my lift will be delivered tomorrow, I'm traveling for business next week. So I won't get around to installing the lift for another week or two.
Black
Kentucky
Looks good.
Going to modify the center cap or grind down the axle shafts in the rear?
MATT0404
MATT0404
NW PA
Looks good.
Yes, forgot to mention that in the OP. As expected, the rear center caps won't clear the axel shafts. I'm not sure which approach I'll take yet. Leaning towards modifying the center caps.
16plati
VA
I guarantee you’ll have rubbing issues with the lift bc the spacers change the geometry in that they will pull all four tires farther into the wheel wells. It’s a well documented issue. Happened on my 16, that’s why I put spacers in to push them out or you’ll look like a guy who skips leg day at the gym. Funny how your $60k+ truck is being modified with $2 zip ties...
MATT0404
MATT0404
NW PA
Understood. ReadyLift says 285/75/18 will fit. With the tires being 30mm wider and the Raptor wheels being +34 offset the net difference should be 5mm on the inside. Sounds like 1/4" spacers should be an easy fix.
Zip ties were only 56¢. No shame here, my friend. :D
julijn
los angeles
has anyone els done raptor wheels on the new expy? looks great like I said in the FB page post pics when you r done with the lift.. cant decide on wheels yet and very well may go with these and powdercoat them black.
MATT0404
MATT0404
NW PA
I haven't seen any other 4th gens with Raptor wheels. Not to say they're not out there, just haven't seen any others with pics online.
My ReadyLift 3/2 arrived today. Being Mother's Day and all, I figured I shouldn't spend all day in the garage wrenching, so it'll have to wait.
julijn
los angeles
I talked to the dealer here on Friday and they told me that they have done 2 expeditions with the raptor wheels. So they told me to look into it....they said they got them on without lifts.
Black
Kentucky
Maybe Raptors wheels but certainly not Raptor 34” tires.
MATT0404
MATT0404
NW PA
Yeah I’m curious how 34s fit a stock height non max 2018 with only sight rubbing
I've put over 100 miles on the Expedition with these wheels/tires since yesterday and only rubbed once while backing into a parking spot. I accidentally hit full lock while cutting the wheel. Otherwise, there's no evidence of rubbing whatsoever. Rear wheels/tires clear perfectly fine with a little tension on the passenger side fender liner.
Excuse my crusty underbody. It's rained all day today and I apply yearly Fluid Film to all my vehicles. So all the crud sticks.
Here they are at full lock:
Rubbing at full lock:
Backed off 1/4 turn of the steering wheel, no rubbing:
Fully clear UCA:
Only evidence of rubbing which was when I was backing into a parking space today and accidentally hit full lock:
Deadman
I like how they fill the wheel wells now vs a lift with a big ugly gap. Not saying the lift isn't needed for the rubbing, but I don't like the big gap after a lift.
Artie
Georgia
Fully clear UCA:
Meh, that rubbing will go away on its own sooner or later.
mattastic13
Corpus Christi, Tx
Dang, I really like that look! It's a shame that you have to modify the rears though Hmmm....something to think about since mine will pickup the ReadyLift on Friday.
No members online now.
rockinghranch
