FORD-EXPY
Low fuel light on. Stopped at gas station to fill tank, once filled fuel gauge showed 3/4 full. After about twenty minutes gauge finally went to full. Operation seems normal now. Anyone else seeing this?
Thats the problem.Thanks for all the help on this
A) I started the Techron Fuel System Cleaner procedure. I have yet to get thru one full tank but will post result
B) yes, I did have the car running as I was filling the tank...I probably do that 80% of the time, but this is the first experience with the gauge being slow. Moving forward, I will turn car off.
Thanks again for taking time to post suggestions
Everyone else filling up at your gas station will thank you for turning your vehicle off while filling like the signs on the pump request you to.Thanks for all the help on this
Maybe the Techron did something, or maybe just running 2 tanks through was all it took.FIXED...!!!!
A) Techron Fuel System Cleaner procedure. Two tanks
B) I kept car turned off while refueling
gauge works perfect. Thanks for all the help....!!!
I give up. Why?Everyone else filling up at your gas station will thank you for turning your vehicle off while filling like the signs on the pump request you to.
To avoid explosion?I give up. Why?
