Help! New phone, no radio display
HavasuMike
Lake Havasu City, AZ
My wife got a new cell phone. She has a 2011 Expedition but the display on her radio doesn't work. How do I get the bluetooth code to do the pairing? I'm not sure what other things will be displayed during the pairing, but I know that when I pair on my 2016, it gives me a code to enter on the phone.
Moderator
You need the code, and the ability to click OK at the right time. So not really any work around I can think of. Time to switch out to an aftermarket radio or fix the factory one...Sorry!
Bobmc
If you still have the old phone, you could look up the connected device list and see if it will display the code.
barrydu4
Louisiana
I recently had a similar problem with my 2013 Ford F150 XLT. The system just stopped connecting with my cell phone. After trying everything I did some research and one person suggested to disconnect the negative battery wire and wait 10 minutes. Supposedly it resets the system. I tried it and it worked. Maybe try this. Hope it helps.
Moderator
Probably won’t help with a broken display...
Moderator
No modern mobile OS will display there existing Pairing PIN. The solution is to pair again, which he can’t because...well he can’t see the pin to pair.
H
HavasuMike
Every once in a while, the display comes back on. I told her if that happens, pair your phone before it goes blank. Does anyone know a way to make the display come back on temporarily?
Moderator
My guess is you have a short. Replace it with a factory unit from a junkyard, or replace with a 3rd Party from your local car Audio shop.
H
HavasuMike
Thanks for the link, Bobmc. I will watch the video and give it a try. I am not great at soldering, but I guess I can't really ruin it if it doesn't work now.
Bobmc
I'm going to try just re-melting the existing solder, rather than desoldering all those pins and resoldering with new. Hopefully, that will re-establish a good connection (if in fact that is the problem)
I'm also interested in theJ-shaped ground spring he mentions. Poor grounds seem to be a recurring theme with electrical problems. I don't think the video mentioned this. Maybe why it didn't work?
And of course give the board a good going-over as the guy in the video does.
bobmbx
Thats called "re-flowing". After the solder turns to a liquid, hold the iron on the contact for ~10 seconds to allow the board and the component lead to heat up further. This will help to prevent a cold solder joint, which fails pretty quickly after a few thermal cycles.
H
HavasuMike
Some good news. I was riding with my wife today and the display came back on. I had her pull over and started the pairing. I got it done but the display went out before I could make it the main phone. Because of that, it won't download her phonebook. Is there any way to make it the main phone without the display?
Moderator
Nope. Again. Get the display fixed. Problem solved!
Mmart
Philadelphia
I have a 2010 EB, my display went dead but the buttons still worked. For what it’s worth I would avoid the soldering. The pins for the back of the display panel are really close together and were machine installed. I’m experienced with soldering and attempted to re-solder the joint but it made the problem worse because that ended up bridging pin connections and that caused the buttons to stop working properly.
Pull the radio and get the part number from the side and search eBay. I was able to just replace the face plate of the unit instead of the whole thing and it only cost me about $20. I reused the faceplate from my original unit and just swapped the circuit boards. All you need is a small screwdriver to get the board off the back of the display panel. Many Ford/Mercury share the same type of plate
https://www.ebay.com/itm/362912907296
H
HavasuMike
Finall got it done. The lights came on long enough to make the changes. Thanks for all your help. I might try the solder thing.
