Not sure about the Expedition transmission....but, my youngest son stripped out the threads on one of his pan bolts on his F350 the first time he changed filter/fluid. I found a stud in one of my "boxes" of old bolts/nuts and it was a perfect fit. The threads to just about all the way through the flange. The factory bolt does not. So the stud threaded into the threads up above the stripped out portion and held just fine when he used a nut to hold that little piece of the pan tight against the gasket.
Don't give up, improvise, adapt, overcome. Darn, I need to watch Heartbreak Ridge again.
Doesn't help with a broken off bolt, but as mentioned by a previous poster, the aluminum threads are the most likely failure point.
