2017 el limited
Mikefromco
colorado
edit: 2017
Do all of the el limiteds come with the heavy duty tow package (3.73 lsd, 4/7 pin , aux transmission cooler, etc)
thanks in advance
JasonH
Houston, TX
MY EL Limited is a 4x2, so it only has 3.31 gears. The 4x4 Limiteds have 3.73 gears. No issues while towing here. Power isn't really a problem with these engines.
intense98neon
Wayland, MIchigan
JasonH
Houston, TX
Super Moderator
Super Moderator
Fords build spec sheets are A LOT of times wrong.
Trust the guy when he tells you what he has in his truck especially if he confirms with an axle code.
It’s like the people that called me a liar when I said our 2015 Max(EL) Limited had LS. It was originally purchased in Canada where it was an option. So it had LS. I confirmed as did the dealer with the axle code. I was going to have a shop put an aftermarket in until they saw what they thought was the code for LS.
Sometimes there are deviations from what Ford says.
TuxedoBlack
MKE
My 15 Platinum was ordered with 3.73 non-LSD. If I want to add LSD which should I choose?
15 Platinum Tuxedo Black
Shawnee OK
I have a 2017 Limited 4x2 and it also has 3.31 gears. Performs great !! However I would not have been disappointed if it come equipped with 3.73 gears.
