Oil Filter Relocation Kit
1970Maverick
orlando, fl
I made up a dual remote system with Aeroquip lines and fittings and universal Derale dual filter base. The bracket I used is a 14 gauge steel construction brace. I posted some pics after I completed it. Look up “Dual remote oil filters” and it should come up. Total cost was about $175. New oil capacity is 8 quarts.
Can you tell me the Derale p/n or thread size for the adapter that threads onto the engine block?
I have a 2017 XLT and I have been doing my own oil changes since the 60s I can't believe how long it takes to change the oil on my Expy. I just installed a Fomoto F107SX drain valve on my last oil change and this remote filter would definitely shorten the time and mess.
I had a Chevy Astro before the Expy, I could do the oil and filter in approx 20 min without ramps, removing any covers or moving the oil catch pan around.
darmahsd
Wilton, NY
My first Expy, a '97 5.4, came with a remote oil filter / water to oil cooler combo as part of the tow package. My '05 has the filter screwed directly into the block. Never switched to that setup, but it's the ideal way to go and will fit all the 5.4 blocks if you could find all the components in a junkyard or for lots more money, Ford parts.
Rainman S
Oklahoma
I have 2 expeditions an 06 and a 14 that’s why I read this forum. I also have a 2015 GMC hd2500 Duramax. It is difficult to change the oil without making a mess because the oil from the filter runs over motor mounts and bar of some kind. I just shove a plastic funnel up under the oil filter after I loosen it a little and all the oil flows into the funnel and out straight down onto a drain pan on the ground. I also have a crossmember that the drain plug oil hits. I park on a slight incline and the oil comes down behind the crossbar. It’s easier than installing some kind of extender kit. At least I think so.
Helo driver
Maryville Illinois
Ok Maverick here you go:
Derale kit 259-15749 $66
Use the 22mm X 1.5 thread adapter
Aeroquip parts:
023-FCA1006 -10 hose 6 ft long $60
FBM4034 90° Swivel..2 qty..$30 each
FBM1014 straight end..2 qty..$12 ea
FBM2009 A/N to pipe..4 qty..$7 each
799-654320 Russell hose separators
anodized aluminum...3 qty..$12 each
I got everything from Jeg’s.
Your choice of filters..mine was the old favorite FL-1A’s. Will be ordering the billet units from K & N here shortly. Washable units, great filtration. Hope this helps!
adwmac6
East Texas
So I am thinking of adding this since ill be doing all my own oil changes. 1 question, why 2 filters rather than 1? I know double the filtration BUT I dont tow at all, so is it needed?
1970Maverick
orlando, fl
Aeroquip parts:
Thanks Helo
1970Maverick
orlando, fl
Good luck with the useless fumoto…...unless you like to watch paint dry. I can remove that nut in seconds.
So you had a Fumoto and went back to the plug? I can remove the nut in a few seconds too, it's the prep ahead of removing the nut and the oil that misses the catch pan that I don't like.
07navi
Mt.Shasta California
The prep? All you have to do is get a rectangular pan (I use a cheap clear plastic little storage container) and position one end directly under the drain. I never could figure out why anyone would want one of those when all they do is slow down the process.
RongWay
RongWay
La Mesa
Aeroquip parts:
Thanks Helo Driver! That looks great! I will definitely be checking it out. And sorry for the late reply, but I never got any notification emails, so figured no one was responding to my question.
Helo driver
Maryville Illinois
Sure thing Rongway! Hey 07navi...have you ever been underneath an Ecoboost engine? That silly pan that Ford has deemed essential business is a PAIN IN MY ASS....Your situation is 180 degrees from mine. Yours... easy peasy... Eco...hassle, messy, ridiculous. I still can’t believe that this is the best they could do. I know my setup is not necessary. It sure as hell doesn’t save money. BUT WHO BUY A VEHICLE AS BIG AS THIS AND WORRY ABOUT EITHER COST OR MILEAGE??? WTF...
rjdelp7
2000 XLT
NY
Turn on the shower and get in. Then have someone flush a toilet or start watering the lawn. The engine is designed to work with the filter it came with. It has an anti drain back and keeps the pump primed. Your new set up may be harming your engine and voiding the warranty.
07navi
That video is proof positive for my setup and a Fumoto valve.
I saw another video where the oil all ran out the back from the filter when the front was raised. I'm thinking you could just use a rectangular oil pan (just and old storage bin bottom is what I use) lone enough to catch it. A Fumoto might be OK if they make one for it but I would probably go with the long skinny clear plastic cheapo pan.
1970Maverick
orlando, fl
Remember that different years use different plugs, covers, filter locations, etc. and I get that everyone has an opinion on the best way to change your oil so take the comments that apply to your specific year and sort out the data then decide.
Please don't recommend anything you haven't done yourself and try to sound like you're the expert.
joethefordguy
There’s always some “karen” more than happy to tell you how wrong you are.
question: why would two filters drop the oil pressure? In this case, isn’t the increase in volume transparent?
07navi
I don't have to own one to know how it works, it's a no brainer.
