Rebecca Hines
Thanks in advance.
Where did you get that number? (It didn't come come from the salesperson at the dealer, did it?) I've never seen a "maximum loaded tongue weight" given as a spec on any trailer. The only number I've seen for a max tongue weight on a trailer is the number stamped into the coupler itself, but those are almost always much higher than the expected tongue weight.Max tongue weight of trailer at max capacity is 837.
You’ll be close, what is the payload in the door jamb of your Expedition? That will be what determines what you can tow. Payload is eaten up fast on these half tons and you have to subtract tongue weight, passenger weight, and cargo weight out of that number. It runs out fast and widely varies depending how many passengers you carry. The tow rating isn’t really achievable unless you are towing a boat or the like with low tongue weight on the truck and the truck is empty.
As an example my ‘07 Expedition EL has a tow rating of 9,200 pounds. Sounds good right? But wait, payload says 1,580....if I have 920 pounds on the hitch (it says it’s rated for it!) I have 600ish left for capacity in the truck. 3 adult weight people in the truck? Maxed out! What about cargo? High and dry. Just be sure to account for all weights.
https://www.ford.com/cmslibs/conten.../guides/19Towing_Ford_Expedition_r1_Dec21.pdfHere are the 2 stickers and then my WDH says 9300 on bumper.
Thanks for your help.
You beat me to it.https://www.ford.com/cmslibs/conten.../guides/19Towing_Ford_Expedition_r1_Dec21.pdf
According to the link above, your max tow rating is 6000lbs since your axle code is “10”. The heavy duty tow package would have an axle code “3L”.
You beat me to it.
I decided your VIN. If you have a short wheelbase XLT, make sure you have HD tow package, or else you can't hit the 9300 max tow. It also appears that you have a taller gear ratio, which means more load on the engine. you'll want a shorter trailer, probably under 25 feet. Maybe someone with a short wheelbase Expedition can chime in. I've only towed with my long wheelbase and the wind will move you, even with sway control. You might want to rent a trailer and try towing to see what you'll be comfortable with long term. A 30 ft with your wheelbase will likely be uncomfortable.
Unfortunately, it doesn't. That sticker is for the hitch itself and all Expeditions get the same hitch. Also unfortunately, Ford includes something called a "trailer towing package" on all Expeditions, which includes the hitch, associated wiring, etc. To get a towing capacity over 6000lbs, you have to get the "Heavy Duty Trailer Towing" package. That gets a bigger radiator, a stouter rear axle, a trailer brake controller and different gears in the rear axle. Only the trailer brake controller can be added to standard Expedition.Here is what my hitch says. I do have the tow package. Does that make a difference?
2019 Expedition that can tow 9300 pounds
Are you saying you have the heavy duty tow package?
