Rebecca Hines
Thanks in advance.
Where did you get that number? (It didn't come come from the salesperson at the dealer, did it?) I've never seen a "maximum loaded tongue weight" given as a spec on any trailer. The only number I've seen for a max tongue weight on a trailer is the number stamped into the coupler itself, but those are almost always much higher than the expected tongue weight.Max tongue weight of trailer at max capacity is 837.
You’ll be close, what is the payload in the door jamb of your Expedition? That will be what determines what you can tow. Payload is eaten up fast on these half tons and you have to subtract tongue weight, passenger weight, and cargo weight out of that number. It runs out fast and widely varies depending how many passengers you carry. The tow rating isn’t really achievable unless you are towing a boat or the like with low tongue weight on the truck and the truck is empty.
As an example my ‘07 Expedition EL has a tow rating of 9,200 pounds. Sounds good right? But wait, payload says 1,580....if I have 920 pounds on the hitch (it says it’s rated for it!) I have 600ish left for capacity in the truck. 3 adult weight people in the truck? Maxed out! What about cargo? High and dry. Just be sure to account for all weights.
https://www.ford.com/cmslibs/conten.../guides/19Towing_Ford_Expedition_r1_Dec21.pdfHere are the 2 stickers and then my WDH says 9300 on bumper.
Thanks for your help.
You beat me to it.https://www.ford.com/cmslibs/conten.../guides/19Towing_Ford_Expedition_r1_Dec21.pdf
According to the link above, your max tow rating is 6000lbs since your axle code is “10”. The heavy duty tow package would have an axle code “3L”.
