New truck, new lift?
Robin Helvey
Crane mo
Hey all, just bought a 2020 king ranch max. Love it so far! Except I think it needs a 3” lift. I think I’m ok on the warranty but how would it affect towing? We have a 7500# GVWR trailer. It has the tow package. Thanks in advance for your thoughts!!
AKentPhoto
New Orleans
I don't think lift companies really test towing. Icon claims no loss of towing capacity but I'd be really surprised if there is any testing behind that statement. Id do saway bars with whatever lift you go with.
This isn't to say you cant tow with a lifted truck, just too many variables unless you have a specific lift in mind and know what it does to shock and spring settings/rates. If it goes softer, there will be a loos of towing capacity.
Fozzy
Riverton
You will not be able to go over a 3/2 lift without major cost of a custom lift. Right now there is a spacer lift, Icon suspension system and the hack with the F-150 shocks. 33” tires seem to be the best setup. I have 35” tires and they rub even after a lot of trimming. People will chime in about using a weight distributing hitch and proper tongue weight. All normal trailering rules apply. The higher center of gravity and larger tires do change the handling, braking and fuel mileage. It is noticeably different than stock but not bad. It’s not like you just put a 12” lift and 40’s on it. The 10 speed transmission and EcoBoost handle the tires and weight just fine. Brakes are a little weak IMO. The Expy is my first IRS vehicle. It handles towing way different than a solid axle truck. You get that side to side motion and in the wind you get the skateboard steer going on. People, including myself are wanting to try the Hellwig sway bar when it comes out. It should help tighten the rear end up a little. I added the Sumo Spring spacers to help with the squat. If the country opens up I can see if they made much of a difference. There are plenty of fairly current posts on all of this.
Tys expedition
Phoenix, AZ
I’m guessing your king ranch has ccd so unless you want to be the first guinea pig the ready lift is the only lift available to you. I’m in the same boat until IVD or some one else comes up with a ccd solution. That being said the ready lift shouldn’t dramatically change your tow rating but it will Affect ride and handling. I think fizzy has the ready lift and he tows. There’s a few others as well that could chime in as that is the most common lift out there
CE750
Austin, TX
The "hack" using F-150 shocks? Please elaborate sir. I just replaced the 3/2 Readylift for the Bilstein 5100 Expedition rears and F-150 fronts, and I'm quite pleased with the results so far. It sits right about where the RL did...with much improved ride, handling, and travel. Installed a set of Icon delta joint UCA's for good measure. Guess this somehow makes 95cobby and I hacks though:waytogo:
Fozzy
Riverton
You just explained a hack. Re read your post. I didn’t say it doesn’t work, but it definitely is a work around.
CE750
Austin, TX
Fair enough! Guess I've just never heard of someone being called a hack, with a positive connotation:handshake:
Concerning the OP's question, perhaps if you're willing to settle with a 1.6" lift vs 3" lift you could go with Bilstein's dedicated 5100 adjustable ride shocks for the Expedition. It would give ya a little boost in height, vastly improve ride and handling, and maintain a slight amount of rake for your towing needs. The 3/2 ReadyLift takes out any rake, and well as my improvised setup using the 4wd F-150 5100 fronts and Expy rears.
duneslider
Utah
He wasn't calling you a hack, he was referencing taking parts not made for the specific purpose and using them for your intended purpose as being a hack. Its a pretty common term. In europe they use the term hacks and bodges. Bodges are more trailside fixes sort of things that you just use whatever is on hand to make a fix to get you home.
Robin Helvey
Robin Helvey
Crane mo
Yep, ccd. And I just found out that the reputable installers won’t touch my truck. I’m bummed about that. I now just hope that a wd hitch will do the trick. No airbags available for it either. It’s gonna squat like a weight lifter.
sanman28
SW MO
Well go to a disreputable installer then.
Robin Helvey
Robin Helvey
Crane mo
Because of the ccd. They couldn’t find any parts If I recall correctly also. No airbags either. Or a brush guard. I’m beginning to think I can do exactly zero things to this truck. :(
Fozzy
Riverton
There are plenty of us with the Ready Lift and CCD’s with no problems. Depending on your tire and wheel choice there may be some trimming. They do make a police style brush guard and the little bull bar. I think they both may need you to relocate your sensors in the front bumper. The Sumo springs do help with the sag and if it sags to much with them you probably need a WDH anyway. The hellwig sway bars are starting to show up and we should soon have reviews from members. This may be the answer to the extra soft CCD normal setting. So you may not have the best options but you can still build a pretty cool Expy with what’s out there.
Robin Helvey
Robin Helvey
Crane mo
Thanks for the help, I will take this to my shop and see what they say. Wdh will be the next purchase, that was already a must. I have a brush guard that I’m thinking of ordering, just waiting to see if I can find one that’s chrome. Hoping for the best!
Mattsmall1972
Marion, SC
I am about to purchase the same vehicle. Can you explain what ccd means? A 4x4 expedition really needs a nice lift imho.
AKentPhoto
New Orleans
If the truck has 22s it's standard. They are adjustable and that is nice to have but they are not what I would call confidence inspiring. I see a sway bar in my future...
