Door ajar light
Butkie3248
So I posted a couple weeks ago on my light being on, i replaced the driver's side door jamb switch light is still on. Now should i do take every other door apart including lift glass and fifth door and try to jump them to see which one it is or is there a easier solution.
Plati
Hard to tell zactly whats going on with your situation, specially over the internet.
My door ajar warning just started becoming a problem again. To diagnose it ... after it comes on - if I open and close drivers door it stops. This indicates that it probably might be the switch in the drivers door. Switch or sensor anyway. I think you have to take the door apart to get to the offending "thingy".
Hamfisted
Ft Lauderdale
Do you have a laptop ? Do you have ForScan ? ( It's free .... Forscan.org ) . It's easy. In ForScan go to the dashboard and call up the I.C. module. Click on the door jamb switch PIDs you want to look at ( all of them...). Hit the run arrow in the lower left corner and have someone open each door while you watch ForScan and it's switch response. Pretty simple actually.
https://forscan.org/download.html
Nice ELM 1.5 USB OBD Adapter on Amazon if you need one : https://www.amazon.com/gp/product/B07MQ8GHG3/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Plati
I made the mistake of buying a NON ELM one. It was cheap $20 and OK. Seems like you also want to have one with USB not bluetooth although I'm not sure why. I don't have a portable computer so thats also an issue. One of these days I'll pony up ... buy a portable computer and a good adapter and get the paid version of Forscan (I'm using Torque Lite). At least I'm consistent, I've done EVERYTHING wrong. LOL.
Hamfisted
Ft Lauderdale
Yeah, I don't really use Torque for anything unless I'm out on the road and just curious about a CEL, but that's pretty rare. Try ForScan on your phone. It doesn't have the extra gauge displays and all that, but it has better troubleshooting aids.
Aspen03
Indianapolis
I have this very issue that started today and need to narrow down the switch at fault. I'm pretty certain it's the driver door as its caused issue before but no amount of messing w it while latched makes it go nuts. Just happens at random driving down the road or over railroad tracks. Might even be wiring. It only takes a couple minutes to remove a door panel but I'm all for tech when it's useful. $50 seems like a steal. HPTuners was WAY more for the last car. Kinda wish I hadn't sold that but other shiny things caught my eye and it was just sitting on a shelf.
I was briefly reading about extended license and access to PATS. I have but 1 key for the Navigstor I picked up. Can I use this to program others rather than go to dealer? If so that seals the deal.
Hamfisted
Ft Lauderdale
Yes. ForScan will program your PATS to accept any new key as long as its cut and compliant transponder.
Wegner44
My 03 EB had the door ajar/dome light on problem, so thought I'd share what I learned.
After spraying all the latches with wd-40 didn't work, I had to find which switch was causing my problems
and I didn't want to dissasemble all 4 doors. There's another way.
To do this it's helpful to have an assistant but flying solo will work too.
Start the car up and start driving. At 10 mph the dome lights will go off regardless of bad switches.
Once they go off, pull over and put car in park, and open the first suspect door from the inside. If the dome light comes on, the switch is ok. Repeat the process (including driving to 10 mph to dim the domes) until you get to the door that doesn't turn the dome light on. That's your culprit.
I copy and pasted this from a previous post but this is exactly how I figured out my issue.
CaptainKrunch
washington
I just left my car turned off. Waited for the battery save to kill the dome lights and then opened each door until I found a door that didn't turn on the lights. Happened to be the last door, passenger side rear. I had sprayed the hell out of all the latches already with no luck.
Took the door panel off and found the switch going to the latch came apart in pieces. I think there was a spring and and a small metal ball. I just spliced the wires together and called it a day.
CldLk-Tim
canada6
CldLk-Tim
canada6
Interior lights staying on when parked. So, yestetday I opened and removed my back liftgate interor molding/Plastic vapor barrier and pulled out both the liftgate lock plug-in and the window lock plug-in giving them both a good spraying of Seafoam Deep Creep (a good Spray Lube) as the hatch was open & pludgins facing downward, the Lube dripped off nicely making a small puddle on the ground. Upon re connect plugins, Lights finally turned OFF.
Butkie3248
Butkie3248
I did this and it's still my drivers door after I changed the switch but I think the problem is the grease but I don't think it's the right electrical grease anyway to clean the grease and put different stuff in....
Wegner44
If you have tested all the other doors and have installed a new door switch that should have taken care of it. If you are still having an issue, then it may something else. That would be beyond my amateur mechanical skills. I wish you the best of luck!
thesavo
Schenectady, NY
@Butkie3248
If you're certain it's the driver's door, and you have replaced the switch, and confirmed it's no other door, your problem may be a chafed wire in the door jamb boot.
Sent from my SM-N975U using Tapatalk
Butkie3248
Butkie3248
So I just happened to do the door thing again this morning, drivers door light didn't come on passenger front didn't come on rear passenger light came on and as soon as I did the rear drivers door I hear a chime, so I closed the door and my door ajar light was gone. So now do you guys think that I may have a shaved wire or something going to that door?
thesavo
Schenectady, NY
It's process of elimination with any Ford door ajar problem.
Spray the offending door(s) with wd40 to free up the latch.
Get frustrated and buy one or all new latch switches.
Open forscan to check sensor states to narrow down the door (often its the driver) or check the cluster if the display tells you which door is open.
Hit with a hammer
Pull open the rubber door jamb boot to find shaved wires.
I'm not saying that is the problem, it's where to check next.
Also, I'm confused, you you say the front two don't trigger any more. Are they disconnected?
My neighbor has an 2003 expedition, and the cluster reports which door is open.
Since there have been lots of back and forth, can you restate what your changes have been?
Butkie3248
Butkie3248
Hit with a hammer
Door ajar light has been on 2 weeks ago I changed the drivers door jamb switch light was still on.... then one of the guys here mentioned driving over 10 mph and see what door would make the lights go on I did that and the two front doors didn't make the light go on and the backs did but this morning before I went into work I redid the doors and when I opened the rear drivers door I heard a chime so I closed the door and my door ajar light went off...so I'm thinking I have a shave wire somewhere in that door.... rear drivers door...
thesavo
Schenectady, NY
It's good to check them all, but start with the one causing the problem.
I have not heard of the drive-over-10mph-cycle.
I don't see how driving over 10 mph makes it different, but I'll bite as Ford does have some strange cycles for other systems.
All fords are different, but I had this problem on my 03 taurus, 98 explorer and 04 town car.
Pulling back the boot is different for different vehicles and even doors. Especially the driver door.
What works for me is to unplug the door harness and remove all the pins, to then remove the rubber sleeve. Some are part of the harnesses and other are just slid onto bare wires.
I would refrain from cutting anything.
Butkie3248
Butkie3248
And then I just to happen to check the two front doors and they both work
