positivemojo
Please let me know your recommendations for rear shocks that will give my Expedition a smooth ride. Thanks!
Do you go a lot on real bouncy roads because my Monroes all lasted many many miles.Thanks for the response but I bought Monroe's two years ago and they worked great at first but are now bouncing all over the place. I'd rather not make the same mistake twice - but who knows, I may have gotten a bad set.
I am wondering the same thing, everybody seems to think because some shocks cost more they are better but actually I think they are worse because they make them stiffer which is very easy to do but it gives the sense of being "better".Is there something wrong with the stock suspension? Are stock shocks no good?
About two months ago, I installed Bilstein 4600s, new factory coils and a 2" front, 2" rear kit. It rides fantastic. I'd recommend the 4600s for sure!
I doubt it any shocks are going to last long on those roads.The ride has gotten very bouncy. It's almost like there's very little dampening of the spring. The original shocks began leaking about 2 years ago and I replaced them with Monroe. I live in North Texas where there is a lot of clay soil and due to contraction and expansion of the clay the roads get really rough - they repair them all the time.
I have Monroe's on the front and they are fine. It's just the rear. Little bumps are not a problem but if I go over a slightly bigger bump that's when it bounces 3-4 times and it shouldn't be doing that. At first the Monroe's were great, but now - not so much. So if I am going to replace them I'm not eager to put Monroe's back on.
I've heard Bilstein makes a really good shock but don't have any experience. I have tried KYB for my wife's car and they seem pretty good. They were pretty stiff at first but settled in after a few weeks.
I don't mind spending extra money. I just want something reliable that will provide a smooth ride.
Thanks. I've been thinking about Bilstein. I understand they don't come with the lower spring collar and you have to use the one off of the OEM shocks. I don't know if the last ones that replaced the OEM have a removable collar. Did you buy the whole rear strut or did you get one with a lower spring collar?
The ride has gotten bouncy. They aren't dampening the spring.
Well, on my 2017 2wd standard wb both of factory rear shocks started leaking after 14 months, about 14k miles. No towing and only good roads. They replaced them under warranty. Replacements lasted about a year, around the 26k miles mark, replaced again under warranty. Hoping that if the third set leaks, it is before the warranty expires.Is there something wrong with the stock suspension? Are stock shocks no good?
Apparently it is a problem that Ford knows about and isn't worth them fixing. Both times it started with a golden, clear puddle on the garage floor. Biggest hassle was that both times had to leave it overnight because they don't stock those shocks at the dealer typically. I don't have the HD tow package, don't know if shocks are different on HD.Good grief. I think I will get mine checked the next time mine's in the shop after this ('15 with 60k).
