AC Questions.
Mmart
Philadelphia
What’s up everyone,
So I have a 2010 EB and I just found that it has a slow refrigerant leak on the long AC lines heading to the rear. I say slow because I had it charged early last summer at the local shop and they did the dye test but couldn’t locate a leak then. It worked all last year and it’s been “ok” this year up until last weekend when I decided to take it back. When it was on the lift he had me come take a look and there is a spot with some dye under the passenger side rear door. Long story short, he didn’t think it was something he’d tackle at the shop.
So here’s the questions just to help me get my head around it. If the rear line is where the leak is, does keeping the rear AC off help in any way? I know there is only a single compressor but not sure if the zones are split by anything mechanical other than the air vents/fans. Secondly, has anyone ever repaired the line itself? I don’t mean replace, I’ve seen some compression fitting kits, just trying to gauge if it’s worth pursuing. Replacing the line set looks like it could be pricey and I could live with having to charge it yearly if it lasted but I’m sure the leak will get worse so I’m trying to weigh my options.
Any input is appreciated, Thx
Dennis_H
DFW, TX
Had the same issue. Line had gotten a hole rubbed in it from the frame. Had them replace the line. Pretty expensive. If you can find a way to put in a splice, that would be great. Not sure how to do that. Was a big job to do. Had to pull transmission mount to get it in there.
07navi
Mt.Shasta California
I spliced mine (sold on ebay) and it worked fine 5 years and then I sold it. The line cost $1,000 and came in 2 pieces (Excursion). No way of shutting off back part unless you get the rear block off kit (ebay).
M
Mmart
Philadelphia
The guy at the local shop showed me all he had to do just to get the line out and then said the labor alone is already high $ and he didn’t even shop the part. I looked up the parts on my own and they were both (hi and lo) around $300 a piece. I’d like to just fix the line if I could. I’ve done enough plumbing to be comfortable with that but I’m not familiar with the coolant portion of the job nor do I have the right tools other than a gauge from a can of ACPro. Have to do some research before I end up costing myself more money. I’m assuming you’d have to empty the system first? Filling it back up correctly is where my knowledge drops off here.
riphip
Memphis, TN.
Empty/reclaim system, repair/replace leak/line, replace accumulator/drier, pressurize, check for leaks, empty system again, pull vacuum, fill system (adding back correct amount of lost oil) to correct amount of refrigerant, check for leaks again. In that order.
M
Mmart
Philadelphia
That sounds easier than it probably is lol. I’m assuming a repair manual would have all the in between details on how those procedures need to be done. Who makes the most detailed? I use Clymer and Haynes for my motorcycle. Are there some specific tools required for this as well besides the gauges?
07navi
Splice the line and have a shop suck it down and refill.
barrydu4
Louisiana
If you can get to it repair it with a flare union. I've used these before in refrigeration repairs.
waleedalmadani
