22" (stock) vs. 20" vs. 18" Wheels
Lou Hamilton
So, I am really considering swapping out my stock 22" wheels for either 20" or 18" ones.
The tires I am choosing (Nitto Ridge Grapplers) are almost identical in stature whether I go with 20" or 18" based on their literature specs.
LT285/65R18: 32.56 x 11.5, 3640 @ 80, 58.33 lbs
LT33x11.5R20: 32.76 x 11.42, 2910 @ 80, 66.36 lbs
I don't do any real off-roading, but do a lot of camper towing. Which wheel size do you think would fit my use case better?
I may do the ReadyLift in the future, but for now it will sit on stock suspension. At that point, I may upgrade to larger tires depending on how it might look after the lift.
Any thoughts, ideas, or pics would be helpful. This will most likely be a winter project so I am in no real rush, but definitely want some ideas to churn around in my head.
JasonH
Houston, TX
Smaller wheel would likely provide smaller moment of inertia and improve mpg and maybe acceleration. Can't speak to ride quality, as I have only towed with the 20s. I think they provide a decent balance between handling and comfort with proper inflation. But I'm debating moving to load range E to reduce squirm while towing. The other reason I like the 20s is they have enough sidewall to avoid curb rash.
2019 Plat Exp
Hallstead
I did 275/70/18s on mine they fit great with no rub at all but I did upgrade wheels to methods that are +18mm offset not sure what you will be running. I know another guy on here is running the 285/70/18 on his stock everything FX4 and said he wasnt rubbing at all. Couple of pictures to show you how it fills out the wheel well. I dont have level or lift on it either thats stock ccd suspension.
scottdm
Western PA
I ended up switching to 20's from the stock 22's and have been pleased with the ride improvement due to the bigger sidewall. I don't have concerns about bending a rim if I hit a big pothole. I also have the CCD suspension and the combination with the 20's seems good to me.
Lou Hamilton
Lou Hamilton
I am looking at Black Rhinos with a 12 offset. Therefore, they will be very similar to yours.
I like your stance. Also give me a good idea of the look since mine it white with CCD suspension, too.
You are running tires a wee bit thinner, but taller. And you said no rubbing? Even at full lock? I am sometimes at full lock backing into a campsite.
2019 Plat Exp
Hallstead
Yea no rubbing yet have about 1k miles on the setup even going up rough rock road with large divets to divert the water didnt make any contact.
Lou Hamilton
Lou Hamilton
I keep coming back and loving your setup. The main differences between ours is my stealth has far less chrome. I probably wont go white lettering, but absolutely loving the gruff that is emotes. Do you happen to have a pic with the tire at full lock?
Now, I am really antsy to get them. LOL! The 18" set up saves me $500, too ($2563 vs. $3087). Sadly, the wheels I want are on backorder. :(
2019 Plat Exp
Hallstead
Yea I can snap a few picks at full lock. I am slowly wrapping the chrome in vinyl to get more of a chrome delete figured I would take a swing at it myself vs paying $750 when the material so far has only cost me like $70.
