22" (stock) vs. 20" vs. 18" Wheels
2019 Plat Exp
Hallstead
I keep coming back and loving your setup. The main differences between ours is my stealth has far less chrome. I probably wont go white lettering, but absolutely loving the gruff that is emotes. Do you happen to have a pic with the tire at full lock?
Now, I am really antsy to get them. LOL! The 18" set up saves me $500, too ($2563 vs. $3087). Sadly, the wheels I want are on backorder. :(
Drivers side I can fit my whole hand between wheel and felt pad on the backside. Passenger side I can get a finger between the tire and the felt liner in the front of the wheel well.
Fozzy
Riverton
I am looking at Black Rhinos with a 12 offset. Therefore, they will be very similar to yours.
I like your stance. Also give me a good idea of the look since mine it white with CCD suspension, too.
You are running tires a wee bit thinner, but taller. And you said no rubbing? Even at full lock? I am sometimes at full lock backing into a campsite.
+12’s are a little to much if you run a taller and wider tire. +18’s seem to be the sweet spot.
Lou Hamilton
Lou Hamilton
The tires I am considering are either taller and same width or taller and narrower.
6mm is about a 1/4 inch difference.
Still waiting on my quote back to see the difference with and without a ReadyLift install.
If I can get the full package of lift kit, tires, wheels and install for less than $3000, It is almost a done deal for a winter project, maybe early spring... well, and an anticipated large commission check. ;)
Fozzy
Riverton
I hope it happens. They look so much better with a bigger tire. But I will say the pics above on a +12 will be rubbing. I’d dump my +12’s if I could find a wheel I like in a +18.
Lou Hamilton
Lou Hamilton
That’s the problem. I’m sold on this wheel that has a 12 offset.
dlcorbett
tx
So, do the 22's ride harsh? Even with CCD suspension?
Not necessarily harsh but the occasional trucklike misstep. Even the 20s on base suspension is a bit stiff at times. The smaller wheels on ccd would help mitigate those sometimes harsh impacts more though.
2019 Plat Exp
Hallstead
I had the 22s and honestly even with the 18s there isnt much of a difference but that might just be from running a load E tire so probably just as stiff of a setup but I wouldn't call either a harsh ride nothing close to what my ram 2500 rode like.
Paul M
Edmond, Oklahoma
Smaller wheel would likely provide smaller moment of inertia and improve mpg and maybe acceleration. Can't speak to ride quality, as I have only towed with the 20s. I think they provide a decent balance between handling and comfort with proper inflation. But I'm debating moving to load range E to reduce squirm while towing. The other reason I like the 20s is they have enough sidewall to avoid curb rash.
This exactly! I have the 22's and can't even look at a curb without a rash forming.
r98exp1
