So on my 10' Expy I have water all over the passenger seat, floor, and headliner. Going through web for cause I've found one of the drains was plugged up. I did my best with can air and weed-eater line and it seems to have cleared it up enough to drain the water when I did a test. The passenger front drain seems odd to me that I can only snake weed-eater line about 8" before I can go no further, but can go much further on the driver side. I partially took apart the headline and pillar covering and cannot find the drain tube much less the drain tube to plug, but whatever, seems to be working now.
But what really concerns me is water tests and seeing how much water is coming in the seams of the sunroof. Poured from a water bottle it's like a faucet, put out in rain is a bit better but it comes in all around the circumference of the sunroof glass. I tried adjusting the 4 torx screws and pushed up the glass a smidgen to see if it would help but it did marginally at best.
So what is an acceptable amount of water to come in? I was assuming maybe some slight dripping, but this is way more than that. And looking at replacement gaskets one, how much better can I expect improvement over the 10 year old present one? Has anyone replaced their gasket on the sunroof? Is it a simple procedure?
