ForScan Tweaks - 2015+
Millerwelds1
Derby, Ks
I have downloaded the latest List and I haven't seen anything about global windows. I've looked through about 30 pages on here and haven't seen anything on this. Is Global windows possible on 15-17's?
Thanks in advance.
Moderator
Thanks in advance.
Nope. Not that I have found. If you find a setup that works, post up!
Langer
Chicago
Is there a way to make the vehicle accept a new remote fob through forscan? For whatever reason mine won’t accept the 8 cycles of on-off in the ignition trick. I’ve tried every permutation I’ve seen a video on, and no luck.
Millerwelds1
Derby, Ks
Do we know if all the windows have modules? My drivers window is the only one that has the auto up/down, this makes me think it won't be possible. Not that it's a huge deal but it would be cool.
Sent from my SM-G975U using Tapatalk
TXFRDOwner
I noticed we dont have HS3-CAN in the 15-17 Expeditions. But I see I-CAN ... is that equivalent to HS3 ?
star-art
Pacific Northwest
My drivers window is the only one that has the auto up/down...
You can add Auto Up/Down to the passenger side by swapping in a motor from a Navigator since they come with it standard for both front windows. You'd also need to replace the driver's master window switch (not sure about the passenger switch) as the wiring is slightly different. You might need to make some minor tweaks to the wire harness as well.
As for the rear windows, on other Ford vehicles there's a door module in each door that directly controls the windows, thus the option of operating all of them remotely. We don't have that option -- even with Auto Up/Down since that feature isn't controlled by a module in our trucks but rather by the door motor itself.
Now, if you wanted to get really ambitious you might be able to install a Ford door module and use it to control your window motor (which you'd have to swap), but you'd also have to deal with the network signalling needed to control it. For example, the switches in vehicles with modules look the same as ours but they don't switch any power. Instead, they're LINbus units that transmit a signal over a single wire to the module.
11henrs
Malone FL
Hey all! I just read all of this and did a few things myself. Thanks for an amazing write up and the time taken to find them. One thing I’m very interested in is an accurate readout for coolant temp. Is that available? Thanks in advance.
m3olsen
CNY
Hi folks, not sure if Forscan thread is best place for this question, but seems like a place to start. I can start a new thread if nothing comes back: has anybody looked for a way to enable turning on the back-up camera while driving? I did searches and haven't found where it's been discussed. I'd love to be able to check the status of ratchet straps on my utility trailer when towing.
Also, I skimmed through multiple pages and am struggling to find link to current version of Forscan file for 15-17 Expeditions - I know it's out there! If someone could point me to a post number or PM me, I would greatly appreciate it. Thanks!
star-art
Pacific Northwest
I haven't heard any mention of being able to override the backup camera using factory settings. But, you can get an aftermarket interface module that lets you put a camera's output on the factory screen. In order to make this work, however, you'd need to replace your OEM backup camera with an aftermarket one. The factory camera has a proprietary LIN-bus interface while an aftermarket camera would output a standard NTSC video signal.
Peeler
CA
Hey guys, I tried a few different ways but can't get the spreadsheet from post 684 to open anymore.
Work for anyone else?
Sent from my CLT-L04 using Tapatalk
craig72
Midwest
Hey gang. Thanks so much for all of the information detailed here! New to this thread as we just picked up a 2016 Platinum 4x4 last weekend. It is replacing our old '98 XLT 4x4 which we've had for 20 years. 277k and still going! Anyway, made it through all 80 pages of this thread and am looking to start digging into making some changes. I've got my eye on a unit and wanted a sanity check.
This type of unit work okay?
https://www.amazon.com/dp/B01F0GVBW...olid=1LA443TI7TPSD&psc=1&ref_=lv_ov_lig_dp_it
I'm interested in the hardwired version since my old shop laptop does not have bluetooth.
Also, over the course of this thread, several links to spreadsheets were listed along the way. What would be best one to use for a 2015 Platinum? Is it the 2014 F150?
Thanks again.
Moderator
Thanks again.
I HATE tapalink sometimes! It is like they have a thing against Amazon. Link sends me to EBay.
If you want the best wired FORSCAN supported adapter, you want an OBDLINK EX.
You most likely will not need a sheet. Most of what you want to do will be in the quick config.
You also mentioned 2 years in your post? Do you have Sync 2(Black background 4 quadrant) or Sync 3(white background 3 quadrant)? 2015’s are Sync 2, 2016’s are Sync 3.
2015-2017 Expeditions are a unique beast. They have a unique combo of modules. Use quick config, drop down change options in FORSCAN and it will save you a lot of headache.
craig72
Midwest
Ooops.. we have a 2016. We were looking so long at 2015's, that was where my mind went. Thanks for the catch. It has Sync 3 and I just updated in via USB last weekend.
I'll take a look at the unit you suggested. Thanks!
craig72
Midwest
I've been eyeballing this on Amazon for a few days, never quite got around to making the purchase. Price just dropped from $50 down to $34. Glad I waited!
Moderator
Yeah, I saw that price. That is a GREAT price!!!
blackhawk2002
AL
Quick question for yall expy owners. I have a 2015 Expedition XLT that had the sync 4-inch screen in it. I upgraded to the 8-inch Sync 3 screen with Apple car play and whatnot. Everything works for the most part. I need some advice on what in Forscan I can change so the steeing wheel controls work for the radio. The only thing that works on there is the volume. Another thing is there is no volume level on the screen when it is turned up or down and lasty there is no audio coming out of the speakers when in a phone call. You can talk just fine, you just can't hear anything unless you put the phone on speaker mode. Any help would be great. All the spreadsheets I tried on here don't work so does any have a sheet they can share for a sync 3 APIM and ACM modules so I can see if I can match it up. Thank you
TXFRDOwner
What does yours show on this line 7D0-01-01 (APIM) xx**-xxxx-xxxx ? .... Mine is xx22-xxxx-xxxx
