Clicking noise from rear AC unit
miket961
Atlanta, GA
Hi All, have a 2017 XLT. This morning I started it and noticed the rear AC was left on from a few days ago. Since it was 28 degrees outside, I quickly turned it off. Drove for an errand. As I re entered, I heard a loud clicking noise from the rear of the vehicle. Engine was off. I couldn’t figure it out and it was too cold to stand around. Drove home.
Just went on another errand and it started clicking after I unlocked the car. And proceeded to click for 30 seconds
Sounds like an electronic motor. Seems to be wanting to close a damper or something in the AC unit.
Does anyone know what it could be? I don’t mind tearing it apart, just not sure what to look for.
Langer
Chicago
Mine just started doing this, too. Haven’t had a chance to tear into it, yet.
M
miket961
Atlanta, GA
Looks like my post was doubled
This video captures the exact same sound I’m experiencing
This video is a different actuator
I’m assuming it’s one of these. I’ll try to narrow it down between the two
07navi
Mt.Shasta California
Don't forget these are earlier models.
M
miket961
Atlanta, GA
Don't forger these are earlier models.
Thanks, there is another video showing a newer model. The actuators appear to be in the same position. All the plastic trim is similar to mine on the outside...I’m certain the part numbers are different and a few other minor differences, but the positioning of them is the same
RobE
Destin, FL
I had the same issue on my 2012 limited. Replaced the blend door actuator.
Jeff12345
Indiana
Just be careful ordering them from
the dealer. Mine likes to send me front ac actuators unless I look at the diagram myself. Luckily they don’t look the same so you’ll know if you’ve got the right one.
easy 5 minute job once you’re started though
M
miket961
Atlanta, GA
For mine it was the top actuator. Went to Ford parts website to get motorcraft part number and found it on sale on Amazon.
Already disassembled the old unit. Disappointed to find one tooth was broken. It’s a 2017 model...I don’t understand interior parts failing this quickly
lbv150
Northeast
It is a common problem. If you don't turn the temp controls all the way hot or cold it seems to prolong getting or prevent the problem altogether. What happens every time you start the truck is the door motor cycles and if it goes to the full stop on either hot or cold it will break a tooth on the gear eventually.
