RANDAL CHAO
Nice. I am sure the bumper plastic would long give up before then.
180w?! For an LED? That doesn’t seem right, especially for the price. That is 10s of thousands of lumens (18000 lumens as a rough guess). Sounds too good to be true, I must say. (I was being a bit facetious with the 2 amps, but 15a seems a lot: maybe it’s true. I’d but an ammeter on it, myself).Most high end off road light manufacturers recommend 12 gauge wire. Long wire runs, sunset to sunrise operation and a more robust cable. Why not? China lights often have way less. I have not cut the harness off yet, but the fuse wire is 14, it may get smaller. If I remember right the math would be 180w/12v=15a. Not 2a. 14 is fine, but the light is 3 times the cost of an Amazon one and way cheaper compared to a BD or Rigid. The fit to the bumper and grill is what sold me. Hope to use it as a driving light. So it doesn’t need to be a crazy BD light.
EDIT: I found the one that @RANDAL CHAO added on Amazon. there's a lot of conflicting information. 540W, 72,000lm, 18000lm, 2.5 amps...But then, it's only $80 bucks...
Thanks BigH
When I get mine installed I plan on doing a drone shot from the top comparing the stock headlights, bar and my A-pillars. I started to mount mine this weekend. I need to get longer bolts and some nylon spacers to put in the bumper gap.
Yup, that’s exactly what I ended up doing as well. Longer bolts and stainless steel washers with self locking double lug nuts.
That aerial comparison will be great! And mine is angled down to shine mostly in front of me. I also ordered the pod lights as well, will install when the arrive.
Where did you get the pod lights from?
From f150leds.com as well
https://www.f150leds.com/collection...tan-series-cree-led-hood-mounted-bar-kit-pair
Not sure they will fit, but I’ll figure something out and get em installed.
Definitely interested. I messaged them about them and they said they weren’t sure they would fit. Very curious how they work out for you.
Nice, what brand/ do you have any links?
This is the Switch Pro 8 switch panel. I used a short Ram Mount to hold it. A ball on the dash and switch panel with the shortest arm.
https://www.switchpros.com
https://www.rammount.com
@Fozzy, what Rigid lights did you get? I have the SDHQ mounts but no lights. What was your purpose for them? Spot, broad beam or combination? Have any opinions?
