Wow thats a dumb question? The g class is faster, but the navigator is smoother, quieter, handles better, way more comfy, has three row of seats, safer, more economical and arguably looks better.
Have you guys looked through Moto dog bisect? Pretty dumb articles and a lot of pigging backing of other peoples work. They had an article “why would anybody buy a Lincoln black label when they could have a G-Wagon”? Yes it’s $30K more for the G Wagon, but if you’re already spending a $100K why not?
I’d love to see that article lol
Didn't read the whole 5 pages...I won't buy another Ford until all the reviews are glowing. We have a '16 XLT we bought new. Within 10k miles it developed a rattle under the dash in the front passenger area that comes and goes. By 30k there was/is a rear shock that is either blown (never saw oil out of it), damaged, or by design lets the rear pogo over parking lot speed bumps. By 50k I had to replace a blend door actuator in the rear AC unit...the main gear in it being some type of plastic that grinds down instead of metal. At around 60k it developed the ominous turbo coolant leak that comes and goes. The stealership says Ford reduced the interval on changing the spark plugs from the original 100k down to 75k. The rear park camera intermittently will be scrambled and can't be fixed without turning the whole vehicle off.
This isn't a machine that is built to last..but I'm betting Ford execs still rake in the compensation.
Have had only a few issues w my 2016 XLT, rear AC feed line cracked and had to be replaced at 50,000 miles and drivers seat side cover has had to be replaced twice when clips holding it snapped off. New one has been fine for over a year now. Bottom of rear hatch door showing some corrosion bubbles, Tires and brakes at 55,000, nothing else. Love my truck.
https://www.motorbiscuit.com/who-on...ack-label-instead-of-a-mercedes-benz-g-wagon/
I used to put a lot of faith in CR because my father used to make almost all of his purchase decisions around their recommendations. As I've gotten older I've learned that CR is nothing more than a single source that is opinion driven by inherent biases of the authors and a limited set of polling data. Just like each and every other "source" out there.
It is nothing more, nothing less.
And out of millions of vehicles sold basing the overall reliability of something on such a tiny sample size is near meaningless. It comes down to personal experience, personal use cases, and a million other factors that can't be all adequately accounted for. And with any modern car.. I would posit that you would be hard pressed to find any model or manufacturer that produces a truly bad/unreliable car outside of anecdotal experience.
Take the cam phaser issue for example. Exactly how many cars and trucks does Ford build that have the Ecoboost? How many are on the road right now? Millions? Even several thousand cam phaser failures amounts to nothing but a statistical hiccup. It's like asking how many pentastar engines does Dodge have in circulation..
And what is "reliability"? It's already been hinted at in this thread. Reliability used to mean "how many times did this car leave me stranded"? Now it's been reduced to seat squeaks and wireless chargers not working though phone cases or "I just noticed a slight hum at max volume coming from speaker 14 of my 18 speaker surround audio system". And with that being the case how many vehicles are given positive or negative ratings based on equipment levels? That has also been touched on in this thread. How it's the limited and platinum trims showing the most problems. Just like with the older ram 1500's. I have a 2013 for work. It's a tradesman. I have had, literally, no issues in 140k miles. Hard miles. Tires, brakes, oil. That's it. But there is also next to nothing on that truck. It has an engine, a transmission, and only the things necessary to make it go down the road legally. There is no balanced climate control system, no infotainment, no electronic safety aids nor automated cruise control.. Nothing. So.. if there was an issue with any of that.. I'd never see it because I don't have it. So what do these "reliability ratings" really and honestly tell us?
I agree, nobody's perfect but at least they have actual data and a methodology to what they do. In their ratings you have to keep an eye on what your needs are and not just blindly buy whatever is "best in segment" as they have to choose priorities to weight more heavily, usually safety and reliability. I do wonder sometimes if an "unreliable" car 20 years ago could even sniff the jock of what they call unreliable now... I think they unfortunately do have somewhat of a vested interest in stratifying reliability and it's hard not to wonder if the gap has shrunk quite a bit. There's a difference between unreliable meaning "less reliable than very reliable" and "too unreliable to own or recommend". My guess would be that everything has gotten more reliable over the last couple of decades but vehicles are still described in that too-binary methodology. I could be wrong though.CR gathers responses from hundreds and hundreds of owners for each vehicle they test. So, by definition, it’s not ‘single source’.
It may not be perfect but if the same method is used across all vehicles then it’s at least likely to be directionally accurate.
Certainly better than the one off “what a lie! My truck lasted forever with no issues!!!” Comment on a interweb board.
There other product tests rely on pretty stringent and consistent testing across brands. They are a non for profit that take no ad revenue or brand sponsorships.
I’ve generally found that the more brand loyal a person is the LESS they like CR.
I’m the complete opposite of brand loyal so maybe that’s why I like their methodology and pragmatism.
