New Owner questions
charlespsu
New Jersey
Hi All,
Just recently purchased a 2020 Limited. Love the thing, especially coming from a mini van like Honda Pilot!
I do have a few questions
1. Do I need mud flaps? My rear is filthy after a rainstorm - what gives? Easy to put on? Factory brand?
2. What gas does everyone use? I've been doing 87, but the manual is vague to me on performance gain using the good stuff! I won't do a lot of towing and plan to use super when I/if I do.
3. What must have accessories did you purchase first?? I love accessories! Lol
4. Does your heated wheel get hot? Mine is not even what I would consider warm. My pilot and wife's jeep steering wheel could fry an egg which I like! Maybe mine is broken?
dlcorbett
Air Force
tx
If your limited doesn't have factory leds, get those asap! The factory halogens are trash.
Timmaaay4
On my 2019 steering wheel I was thinking the same thing about it is barely getting warm yesterday while I was driving it also.
2nd the headlights
Sent from my SM-G970U using Tapatalk
Expedition Dave
A Tiny Little Dot in Florida
Mudflaps--yes I would say so even if you have running boards. I have Weathertech and was happy with ease of install, however it looks like it can accumulate debris behind the flap--which may not be a big deal. If you add taller/wider tires, it may rub--but this may be the same with any bolt on mudflap.
87 octane, top tier gas: Shell & Chevron for me. You WILL get more power with more octane (91 octane *may* be the cap) and this is a bonefide FACT (dyno proven and timer proven). Some claim an increase in mileage but I have not seen it and those that have seem to be .5 - 1 mpg and I am guessing that is a result of mixed and city. Highway steady state, no different. To me, truck is definitely more snappy with the higher octane, YMMV and you pocketbook.
I bump octane if I plan on carrying a decent load or towing.
Mods? Your call...
mwl001
Scottsdale AZ
Mods? Your call...
I'll second 91 octane while towing, I also use in our hot summers in AZ. Stick with top tier, it's more important than octane. I also installed the Weathertech rear mudflaps and have been happy with them so far. Install was a little finicky but I think it turned out well and I liked the no-drill install.
mcb345
Nashville, TN
If you dont already have the rear “expedition” branded rubber/plastic cargo mat it is pretty great.
It Velcro’s directly to the carpeting and allows you to fold seats up and down individually. I tried weather tech, husky and one other before finding this, it’s a must have IMO.
For my non Max 2019 it was this part name and # below.
Genuine Ford Cargo Area Protector - For Non-EL
SKU part # LL1Z-6111600-AA
Heated steering wheel is disappointing for sure. You CAN replace the steering wheel with the Raptor steering wheel, not sure if it’s heating element is any better though. Doubtful.
5280tunage
colorado
The steering wheel elements are identical. Used forscan to increase the temp. Worked like a charm.
Timmaaay4
What is the steering wheel temp setting under in forscan?
Mlarv
Eastern TN
Here are the settings for the F150 if you want to play with them.
714-02-01: 0244 4444 xx - Wheel Temperature = 68ºF
714-02-01: 024C 4C4C xx - Wheel Temperature = 76ºF
714-02-01: 0254 5454 xx - Wheel Temperature = 84ºF
714-02-01: 0258 5858 xx - Wheel Temperature = 88ºF
714-02-01: 025A 5A5A xx - Wheel Temperature = 90ºF
714-02-01: 025C 5C5C xx - Wheel Temperature = 92ºF
714-02-01: 025E 5A5E xx - Wheel Temperature = 94ºF
714-02-01: 0264 6464 xx - Wheel Temperature = 100ºF
* Higher temperatures may negatively affect the lifespan of your steering wheels heating element.
Dspud2006
Staunton IL
i just bought a 2020 Expedition Max XLT. I am pretty sure I have regular halogen headlights. I noticed my gfs wrangler rubi with LEDs has much better headlights. Can I just replace the bulbs or do I need to do the whole fixture? Any recommended bulbs?
Matthew Abrams
Washington, DC
Welcome! Recommend doing a search here. there are a ton of LED bulb related posts that will put you in the right direction
Goclmbmnt
Just upgraded mine last week from halogens to oem led headlights and tail lights. Night and day difference... absolute must.
Jimmer
Eau Claire, WI
Dave, I was watching an install video for the WeatherTech mud flaps and have a question.
Obviously pretty straightforward, I am just wondering if you did anything to protect/seal the painted flange on the truck that the U-Nuts going around. Even though the body is made out of aluminum it seems to me that the metal on metal nature of the u-nut to the body leaves potential for the Ubolt to rub the paint off the body and corrode over time- especially since it's low on the truck and I'd have to imagine the flexible mud flap moves around a bit with wind drag and snow/slush/mud hitting it.
Thinking maybe it would be a good idea for me to spray a little Amsoil HD MP around there at the very least or maybe even some sort of caulk to protect the metal under paint?
Expedition Dave
Honestly, I don't recall the install much. I uses to do a lot of "how to" stuff but I remember it being not that hard and I think the only thing I recall was just cleaning surfaces of existing grit. I've also gone from zero humidity, to high humidty and salt air, and now to roaming the East coast for the next 9K miles during snow/salt storms. Maybe I'll have them take a look when I eventually get the Bilstein 5100 shocks installed...
Lou Hamilton
I took no precautions when I installed mine.
5280tunage
colorado
I didn't either, but I did drill some extra holes and use some of the plastic push pins to attach the inner parts of the flaps to the well liner, just to make it a little more sturdy. Front and back.
Fizzy
Alberta, Canada
Regarding the heated steering wheel, the manual states the following:
Note: The system uses a sensor and is designed to control the temperature of the steering wheel and to prevent it from overheating.
Note: In warm temperatures, the steering wheel quickly reaches its maximum temperature and the system reduces the current to the heating element. This could cause you to think that the system has stopped working but it has not. This is normal.
So, it’s not a single fixed temperature. It varies.
Ours is very hot. Painfully so sometimes. But then a while later it’s much milder.
Admittedly it could be the ambient temperature being SO low here, maybe causing the car to go overboard with the heating.
Fizzy
Alberta, Canada
I bought the Weathetech one, and I’m disappointed. So, the official part you posted has a split down the middle to allow the 3rd row seats to raise and lower individually?! That sounds fantastic. Do you have a photo you can share?
